The Perfect Proton Satria Neo?
mona-vie
Singapore
I am thinking what could be the perfect Satria Neo?
Satria Neo with S2000 wide bodykit (or bodykit of your choice)
4G63T Engine + Gearbox (small turbo probably GT28RS to reduce lag)
4WD conversion.
ECU of your choice (I will use a Vipec V44)
!!RIP OUT ALL CRAP PROTON ALARM!!
AP Racing or Brembo brakes
18" Rims and 235-245 tyres.
Ohlins coilovers (taken from the Satria Lotus version)
I think it will easily have a 0-100 of 4s and will go thru Sepang really fast.
Its going to be a silent killer as well....
Evo/WRX etc owners will brush aside the proton badge car as something unworthy of their time and be surprised!!
for me i choose the 1st version satria neo r3, black with red stripes 1.....
with 4g63t engine + stroker kit.
thats all, confirm can tapau subaru :)
just get the satria neo clubsport with built in rollcage and plunk in 4g63t and 4wd
pretty basic to become to monster
No, I already have the stock neo so I have to work from there.
But roll cage? Cannot cause its a daily driver.
no im just saying if u didnt have your neo
you could consider the neo clubsport
its completely road legal because the roll cage is FIA approved
that is the main advantage of the car over other road legal proton cars :biggrin:
and its super limited edition and rare
wish i had one :adore:
i wish that malaysian Road&Transport Dept would allow this modification to our car :biggrin:
http://photos.autoexpress.co.uk/images/front_picture_library_UK/dir_24/car_photo_12093_14.jpg
Nissan GB has created the craziest, road-legal Micra ever. It’s called the R which is just what you’ll be screaming when this mid-engined, mad little car rockets you to 62 mph in less than five seconds and onto a 150 mph top speed.
Engine
Configuration Straight 4
Location Mid, transversely mounted
Displacement 1.999 liter / 122 cu in
Bore / Stroke 86.0 mm (3.4 in) / 86.0 mm (3.4 in)
Valvetrain 4 valves / cylinder, DOHC
Fuel feed Fuel Injection
Aspiration Naturally Aspirated
Power 265 bhp / 198 KW
Torque 250 Nm / 184 ft lbs @ 6000 rpm
BHP/Liter 133 bhp / liter
Drivetrain
Chassis/body unitary steel
Suspension (fr/r) McPherson struts, coil springs over dampers
Steering rack-and-pinion, power assisted
Brakes ventilated discs, all-round
Gearbox 6 speed Sequential
Drive Rear wheel drive
Dimensions
Weight 1000 kilo / 2204.6 lbs
Length / Width / Height 3715 mm (146.3 in) / 1760 mm (69.3 in) / 1490 mm (58.7 in)
Wheelbase / Track (fr/r) 2430 mm (95.7 in) / N/A / N/A
Performance figures
Power to weight 0.27 bhp / kg
Top Speed 240 km/h (149 mph)
0-60 mph 4.9 s
so basically the bodykit use s2000spec. with road legal cage...engine and other running gear also same as s2000 spec. but engine location on rear seat where the car becomes Mid-engined Rear wheel-drive :biggrin:
awesome :driver:
yes, the roll cage in SN Clubsport is completely road legal. But i heard its not FIA approved.
FIA regulations is 45mm diameter but the SN Clubsport was 42mm diameter.
ohh i thought it was FIA approved thats why it was deemed road legal
then if its still road legal thats awesome :biggrin:
u just too influenced by brand name..
roll cage never legal in car...bar the clubsport neo..
why 2 litre upfront?
front heavy...and will have quite a lag for 400hp..(to reach 4sec 0-100 time)
why not 3 litre mid engine....haha
1.6 litre supercharged/turbo seems enough for front engine....
:: ~ want fast car go straight to evo :) ... the cost for a neo + enjin + all type of mode you want to put in = one recond evo 7,8 or 9.... i know it would be powerful, brutal and 'jahat'... but will the car(Neo) handling and feeling good as the evo? i don't think so... remember, ori thing are more better than replica... want more faster engine for neo, 1.8 GSR more than enuf ody :)
fit 2JZ single turbo,
AP racing brakes,
17" TE37's
REMOVAL OF ALL UNNECESSARYCRAP!
ALCANTRA DASH AND STEERING
DIGITAL HKS METERS
SEQUENTAL GEARBOX
This would fly if it had wings :p
AP racing brakes,
17" TE37's
DIGITAL HKS METERS
SEQUENTAL GEARBOX
2JZ on a neo??..LOL..won't the front feels too heavy?..engine bay big enough?.. :hmmmm:
I'd just strip the neo, ITB's, highcams, highcomp internals + balanced engine, LSD, coilovers,semi-slick tires then just go tougeing.
Whats the point of a nose-heavy but fast hatchback? Might as well get something thats made to handle the power :driver:
thats why in previous post i opted for the engine to sit on the rear at passenger seat :biggrin: :adore:
In terms of ‘perfect’, it would not inclined to performance only..
It should have lightweight engine…(maintain the stock weight distribution and less total gross weight)
Torquey and lively engine (1.6L Campro CPS (be original!), supercharged, medium compression, 300hp, ron97)
AWD, mainly to rear wheel…only distributed to front wheel when detected rear wheel slip…
Semi automated manual transmission…not tiptronic nor sequential…
Reduced NVH for interior...2 din display with everything available…
Good audio setup…5.1 channel…lots of sound deadening/dampening, roof, floor, trunk, hood, door, mudguard..
Smaller thicker alcantara steering wheel…with paddle shift…
Better design and lower seat…good lateral support…easy in-out…full reclining…
Better grip pedal..or maybe change floor mount pedal…
Arrrr…its nice just to write the dream neo…
Further on…the suspension should be comfy but sporty…take magnetic type like Ferrari or air like Mercedes…self leveling, self dampening…
Do not overbrake….a new words?..simple but reliable setup…street and track able pad and rotor…if not, just opt for Stoptech, 1 setup for all…
AP? Brembo? Why focus on brand name? Why focus on number of piston? Does having AP or Brembo badge automatically makes the car stop shorter? Does number of piston affect braking power?
Maintain ABS…EBD…or whatsoever…make it electronically adjustable, from inside..
LSD is a must…type depends…electronically control maybe, like Ferrari…
Put on semi-slick…rim size doesn’t matter...
Exhaust got valve…quite in city…loud at WOT…
Flat underbody…working diffuser and splitter..
And last thing, don’t remove the Proton badge…be proud!
Haha babi bising weiii, imagine the HEAT coming off that :biggrin:
But still yeah, that would be intresting. I really wonder how much Malaysians can get out of our humble Neo...
Handlingwise, screw power. :driver:
i rethink on my previous post
Perfect Neo for me:
An Entire chassis made of Carbotanium (Like on the Zonda Cinque)
Light Weight 16" Allow rims
A More aerodynamic body (S200 body most prolly)
Stick with Campro but Tuning lae!
Car settings as seen on the Subaru Ver.10
4WD
Magnesium suspension
6 Speed Close Ratio GB
Batman Logo
DONE :proud:
