EG clubs/owner etc
All Honda kaki's...Tomei-R is organizing a TT sessions on this upcoming Mon night since Tues is Labour day should be fine i think,need confirmation on how many can attend too...Detail are given below...
Date - 30.4.2012 Mon
Time - 9.30 pm
Location - Petronas Station opposite Eastin Hotel PJ
unfortunately...cant make it.
gonna be awhile before i can join this whole car thing with the baby around.
OMG..... seems like my valve cover washer kit oil seal (the one used to screw the cover) is leaking....but i do check just now got loose... now tighten it and see how tomorrow.. btw, if change the seals like our ddv bro had done.... how much will be the seal cost normally??
to all otai, what camshaft can u recomment me to buy if i have a stock b16a with lintah air filter, rechip ecu and b18 ss header with full piping. thinking of buying new camshaft with valve spring and retainer.. thanks in advance..
wat kinda power u looking for?
theres the usual suspects....skunk2, toda, jun, brian crower, etc etc....
best bang for buck is B16B of course...
but a friend of mine did mention that the crower stage 2 was suitable for small displacement engines
---------- Post added at 12:31 AM ---------- 6 hour anti-bump limit - Previous post was at 12:30 AM ----------
oh and forgot to mention....when putting aftermarket cams...its best to have some sort of programmable engine management....chipped ecu doesnt even come close to being enough...e-manage with ignition harness would be the best bang for buck.
more kick then the oem b16a but streetable... besides b16b ( use items hehehe ) what other cams that i can look for without to do anything to the head and block?? thanks for the feedback...BC stage with the valve spring and retainer? how much gain can he get from that set up??
most cams with proper tuning are streetable... the only cam i know thats very tough to make streetable is the toda killer cams.
BC...dont know....he only said that only...didnt bother asking anything else...
check on skunk2 pro2...or skunk2 pro1...especially check on the recommended compression. also check on toda C or toda c2 as well...
again..with proper tuning...which means ull need adjusable cam pulleys as well as management.
my cam??? B18C Type R...targetting Toda C2 though
with S300
Talking about cams, I was talking to a Singaporean who also frequents the same workshop as me. He says that aftermarket cams are mainly for high rpm. So, he says we don't really need it. He says that how often we drive at that high rpm.
Do u guys agree? I thought the power is throughout the rpm.
hes correct to a certain extent...
some cams give more benefits on the higher rpm range while some cams benefit the mid range...
havent heard of any cams benifitting low end range though... heh
reiden... why la?
It really depends much on the setup of your car and what it is meant for... Track, drag , autocross etc. IMHO Jun type 3 cams are the best. Skunk Pro 2s at not bad either. All have different profiles so you have to study them. Different tuners will recommend different cam setups for your cars. But u must bear in mind that these two cams are meant for engines with mid to high end upgrades with a higher compression ratio setup. Aggressive cams like the Jun type 3 are not meant for stock engines. Heard from my tuner that if you have a stock engine and u put in an aggressive cam like the Type 3, your powerband will actually take a dip and could come out worst than your ori cams. You really have to talk to the your tuner regarding which cam would be best for u with your current setup.
agree with tomei... also not forgetting which cams ur builder/tuner is more comfortable with...
i initially wanted the pro2s....but my builder is a toda guy...n recommends the c2 for my b20....hence the reason im targeting them...that and also he gives a pretty good price on them..hahahah
ic2.. so madman what is your currently dyno hp if u mind to share?? my target is atleast to ctr 185 hp...heheheh any good recipe to achieve there kind of nvm...
ur target 185 on wheel or on crank?
my high comp 2L with B18C-R cams and chipped ECU + VAFC is at 187hp on wheel...
FYI, B16A with B16B cams +, B16B pistons + Type R intake manifold and TB will give u about 170-175 hp on wheel....few friends had this setup last time
wow with your 2L set up 187 hp on wheel..maybe i was aiming to high... lower my target to get 175 hp atleast i must do the following set up..can i just buy a b16b kosong only and just plug and play to my eg9 with b16b im and tb with rechip using crome...sorry for lots of question... will it worth it compare targeting to cam etc...can b16b use aftermarket spring and retainer ( which is recommended by you guys) without using the b16b spring and retainer??
