r35 should use ron97 or 99?
Should use RON97 as RON99 is not available here in Malaysia.
haiya....big problem maa..maybe must use additive to up th ron.....sporty and luxury car like that must use higher ron for better power...
But in the US, there's no RON >97, yet R35 is avaliable there.
Depend on state, some state even sell E85.
---------- Post added at 01:36 PM ---------- 6 hour anti-bump limit - Previous post was at 01:34 PM ----------
open d fuel door ,it says must use ron100 else could damage d engine .,.,....
Better get a proper tune for malaysia fuel quality, like most import sport car do. If not u risk damage the engine in high boost for long run.
Yeap, it surely can be tuned to fit the available fuel or else it won't be widely sold here & in US.
Believe it or not, a GTR's ECU is smart enough to retard its ignition timing when it detects knocking. So I don't think you have anything to worry about knocking as its ECU is advanced enough to stay out of trouble.
Even current Nissan sentra has knock sensor and variable timing control...so not much of a prob
can't remember where I've found it, but me think there's a R35 tuned to RON95 by local tuner but dragged in Thailand..
...heard it achieve 1000bhp?
Yes.. modern car have knock sensor, but do u really wan your engine to retard timing till limit n jump into limp mode..? detect knock when u on boost..? Continues of knock count ecu will jump into limp mode, limiting boost, running rich, lower timing, this is not good for the engine health. This is happen even with a tune ECU, u never know when u going to fill up crap fuel malaysia have.
water meth injection might help. reducing knock and lowers the internal temp.
dont know on R35 though..
If u new car remember to get your camber check, stock tend to have massive negative camber if u not a track guy...
crap fuel?
