Ooo aftermarket GCI lamps ah? nope....cant afford...
1. ATF cooler will always be hot. optimum temp is around 80C. also, replace the hoses and make them direct from gb to ATF cooler. Proton installs the hoses go thru the radiator.Here are the problems:-
- GB atf cooler is always hot. I've change the ATF oils to synthetic. Need to pour some water to at atf cooler to cool it down.
- Jerks a lot when down shift and up shift.
- I thought of changing the GB to a better GB from mit. Any recommendation?
- Engine jerks.
- when i drive at night, lights seems to be very dim and dash lights as well. after driving hard for awhile everything seems to be ok or back to normal. I've checked the charging alternator and its good. Same goes to the battery. Can anyone tell me whats the std battery size for perdana v6.
- Sometimes can't start. No crank. Need to turn the keys at least twice before starting up.
Can anyone please help me please. Thank You.
my fren who works at NHF (the original producer of the projector headlights), have used the headlights for more than a year without any problem.guys, anyone installed these (lamps)?
hows the LED life span...cause those "brothers" kindda barang...LED cant tahan :P
hello guys , nak tnye nie . aku ade 1 perdana sei . tp gear auto . nk change to gearbox manual , agak2 brape ? ade jenis2 gearbox ke ?
hi guys,
I got 2 pc of Toyo Tyres to let go... Price Nego till sell.
http://www.zerotohundred.com/newfor...425462-18-toyo-proxes-t1r-tyres-for-sale.html
Hi guys, i just bought my 2001 PV6 in a week! So far am happy with my car. I've already service the engine, change engine oil, oil filter and change the atf fluid. I'm yet to install ATF cooler for my gb. Any recommendation from you guys? JASMA,HAYDEN WORKS?
And maybe you guys could assist me on what to do next.
** go for hayden bro.
I heard it is standard for a V6 to have wind noise when speeding more than 100kmh. How to void the wind noise? need to replace the rubber trim or......? no idea how to solve.
**there is a chrome strip on your windscreen frame, that is the common problem, if its not then time to change your rubber linings on all doors.
Other than that, I love my new V6 even tho bought 2nd hehhehehe
Just dropping by to say Happy New Year Guys, drive safe during the long holidays as most people will be clearing leave and going places or balik kampung :)
Currently timing belt reaching 90,000 Km already. Was thinking of asking mechanic to just jack up the whole engine and check for oil leaks and change all the rubber seals / hoses /connectors and replace timing belt / spark plugs / water pump 1 shot. Considered semi major service lah i guess.
Btw NGK iridium IX with the 0.6mm tip really does last longer than the denso iridium 0.4mm tip. And tried Amsoil fully synthetic 20w50 which runs pretty well and minimal sluggishness even after long fast drive. Maybe its just placebo effect.. I dunno :)
Zeus : Your Rm105/450KM is city or highway or Mixed ? If fully city... ok lah... its around 18-25 cents depending on your right foot :)
1] From DEVICE A
input voltage: 4.75V to 5.25V
max input current: 0.1 mA
output voltage range: 0.50V to...
