tcw-3 is marine grade 2t oil..
used for outboard 2stroke boat engine.....
got some brand like quicksilver and maxoil
"Actually your not the first to send me that But thank you.
It is very focused on two stroke applications and not as a fuel mix as you know. We do not look to the 2stroke oil as a lubrication for our crank/cylinder/rings etc.
What we are discussing/testing/sharing has more to do with certain properties in the TCW-3 that make it a excellent fuel add to gasoline in a 4 stroke engine. Also our mix ratio is significantly lighter.
With that said....I do not see anything in the JASO FC spec that scares me adding it as a fuel add in a 4 stroke.
Thank you for participating and adding your thoughts/experimenting with us."
Yes outboard marine engine most of of the time rev at higher rpm and for longer duration....
Next will compare a cheap grade and synthetic grade see which have better ratio price over performance...
if you guys remember this
[/COLOR]
i think outboard engine got lower rev then a motorcycle, and its water cool so the condition is almost identical as in a car
remember, over dose will kill fuel pump. My car is on the 4th fuel pump. The last change was 4 months ago but that was accidentally over pour about 200-300ML. Semi dead after that tank of fuel finished. At long drive, the pump got heat up and malfunction. AFR at 9k rpm @ 12 suddenly cut by ECU and the rpm unable to go up to 6k where the AFR become 17 then 5k then 4k then slowly the car dead and need to wait for long time for the fuel pump to cool down before able to start the engine. Short distance no problem.
hmm me too tot it suppose to lubricate the pump, mayb too much caused drag? but even at 200ml to a full tank it is really not much.
After switching from 2t JASO FC to TC-W3 with the same ratio mix TC-W3 have better pulling power and mileage notice improve abit from JASO FC grade too...
Thanks
