Good lord. It's a tyre from around June 2012. Saw a 2612 on it.
Also, treadwear 340, traction AA, temperature A rating? I kinda wonder how they do the traction and temperature rating.
Temperature nothing to worry about as A already the highest.
Traction rating is straight line braking G force in wet.
For your reading....But a lot to digest.....
Traction Grades
UTQG Traction Grades are based on the tire's straight line wet coefficient of traction as the tire skids across the specified test surfaces. The UTQG traction test does not evaluate dry braking, dry cornering, wet cornering, or high speed hydroplaning resistance.
The Traction Grade is determined by installing properly inflated test tires on the instrumented axle of a "skid trailer." The skid trailer is pulled behind a truck at a constant 40 mph over wet asphalt and wet concrete test surfaces. Its brakes are momentarily locked and the axle sensors measure the tire's coefficient of friction (braking g forces) as it slides. Since this test evaluates a sliding tire at a constant 40 mph, it places more emphasis on the tire's tread compound and less emphasis on its tread design.
In 1997, the UTQG Traction Grades were revised to provide a new category of AA for the highest performing tires in addition to the earlier A, B and C grades. Previously the A grade had been the highest available and was awarded to tires that offered wet coefficients of traction above 0.47 g on asphalt and 0.35 g on concrete. Today the grades and their traction coefficients are as follows:
Traction
Grades Asphalt
g-Force Concrete
g-Force
AA Above 0.54 0.41
A Above 0.47 0.35
B Above 0.38 0.26
C Less Than 0.38 0.26
Unfortunately the immediate value of this change to tire buyers will be limited. Use of the AA grade will first be seen on new tires that are introduced after the standard was enacted and will then appear later on tires that have had the required wet traction all along, but were introduced when the single A was the highest available grade.
Temperature (Resistance) Grades
The UTQG Temperature Grade indicates the extent to which heat is generated/ or dissipated by a tire. If the tire is unable to dissipate the heat effectively or if the tire is unable to resist the destructive effects of heat buildup, its ability to run at high speeds is reduced. The grade is established by measuring a loaded tire's ability to operate at high speeds without failure by running an inflated test tire against a large diameter high-speed laboratory test wheel.
Temperature
Grades Speeds
in mph
A Over 115
B Between 100 to 115
C Between 85 to 100
Every tire sold in the United States must be capable of earning a "C" rating which indicates the ability to withstand 85 mph speeds. While there are numerous detail differences, this laboratory test is similar in nature to those used to confirm a tire's speed ratings.
Unfortunately for all of the money spent to test, brand and label the tires sold in the United States, the Uniform Tire Quality Grade Standards have not fully met their original goal of clearly informing consumers about the capabilities of their tires. Maybe it's because tires are so complex and their uses can be so varied, that the grades don't always reflect their actual performance in real world use.
---------- Post added at 04:06 PM ---------- 6 hour anti-bump limit - Previous post was at 04:05 PM ----------
The last bit, that one need experience and contacts.
You learning a lot here, right?
