Ivan's AE101 Build Thread 4AGE BT 20V6Spd No 56K
NEW OEM Clutch Brake Rubber 4-3-14
NEW OEM Clutch Brake Pad
Fuel Lines Cover 4-17-14
Donor Car...
Will be using one OEM Feed Fuel line as for return and the Cover for it.
Cleaned and Ready...
Intalled on place using all OEM hardware.
Custom Feed Line and Return Line in Place...
Done ready for the Fuel Pump Assembly...
In Line HR Fuel Filter 4-24-14
Hybrid Racing In Line Fuel Filter...
Yeahhh I'm ready!
Intallation...
In place...
Intalled...
Fender Brace 5-5-14
New Portable Tool Box
Fender Brace In Place...
Need to make a hole to install the nut that will hold the bolt of the brace.
My Friend Michael Helping with it...
Installed...
Installing Custom Tucked Fuel Lines 7-7-14
The Fuel line was hidden routing installed...
Now the return line won't fit as I want it to the new routing... I have clearance issues with the Air Box plate...
Install the back plate bending a bit the Return line.
With a lil Bent goes right there...
Thats how it looks in the new position...
And here a example of the routing, just need to hide and attach it behind the Feed Line...
A small piece of advice for the fender brace if you seek real chassis rigidity. Weld it permanent. Myself and few folks confirmed it from trackday it gives way better handling.
Will note that on the to do list for the future plans!
Thanks for looking Man!
Air Box Fitted Fuel Lines 7-15-14
Installing the OEM Air Box
Installed and Fitted the Tucked Fuel Lines
Another view, how hidden are the Fuel Lines. Now I'm Happy with that routing...
Officially the Tucked Fuel Lines Complete!
Planing Clutch Line Routing 7-16-14
Tucked Brake Master Cylinder Lines
Brand New OEM Clutch Master Cylinder
Routing For the Line... Trough this hole and Behind the brake line...
And behind the Transmission to the Clutch Slave right there...
JDM Oil Filter 7-21-14
This is how look the Media of the Made In Japan Filter Vs the Thailand (Paper) ones...
Part Number 90915-10003
Rep OEM Filter 7-23-14
Toyota Replace the Made In Japan Media Oil filters for this Thailand Made Paper ones... :facepalm::facepalm::facepalm:
