spring/retainer only can? :P
My friend have.
Will check for you tom how much he want to sell.
hi chris... seem u r very experience in cams... what do u say about CTR cams...? juz wanna hear ur frankly voice... tq...
agreed with u... before CTR, i used JUN3... as like u said, CTR cams more to street use... i have not do any dyno before... but marking with same car n setup, JUN3 will produce more power at top end... can rev to 9k rpm without any lack... it gave the different result... but since i'm using CTR, i feel that CTR have a better power from low to 7.5k rpm... the best part is when hi lobe activated... i can say that if want to feel the vtec force go for CTR/ITR... my question, is there any cams will give the feeling and in the same time more power... as per u mentioned before buddy club and omni stage1 are great for street use...
sumtime we need overlap rite...
how much u take for setting cams...? a set n run or there will be many set n run...?
engine theory says more rpm more power... i've try several combination to my CTR, in-standard, ex-retard, i will say the bottom end great till +-7.5k rpm... in-retard, ex-retard, poor at bottom but the power rise till +-8.5k rpm... this is what i feel... i'm using vafc with wideband... the ignition mostly fair... for distance 400m, the 1st setup gave lower time... wat do u think chris...?
i'm curious...how come Toda (Japan) produces valve spring but not producing the retainer for it?....anyone knows?...
me using dial gauge too... but i'm dont have so much time like pomen...
i didnt get ur interpretion of advancing regarding to reduce overlap... exhaust or intake... if exhaust, yes...
last nite i just red your sr3 track car in hypertune... very big pentagon eh... if i open shop, i'll give name white house... hehe...
