20V BT 0 - 100 kmh performance
t4kak0
have u all test 0 - 100 kmh with ur 20 BT b4?hahaha..if yes, share it here..below is my result : -
SEG AE101
20V BT (A/T)
SHELL (without V-POWER)
14" tyre
Stock exhaust
0-100 kmh = 10.03 sec
hmm...you sure it's 10.3 sec? thats abit slow rite?~
hahahha..just wonderin la..no offence~
cos my 1.3 2e also manage to get like 12-13 sec~
so i tot 1.6 should be like under 10 sec mebbe 8-9 sec
Hmm..what Alan said is true. Is it true about that?
Cause 4AFE also can do below 10sec if done properly...or somewhere near 10sec plus minus...
m.... is leter bid slow. I oso test my 1 . My 1 20v bt auto 15' rim can get 9.++
yeah.. bro nnik.. nedd another guy side at passenger seat enuf //..
my car ae101
SVT manual
15" with twin muffler
can get 9.++ seconds...1st n 2 nd gear tyre slips also ..haha
slip..heheheh tat need lsd gearbox la...hehehehe...
where can get lsd gearbox for BT/SVT engine huh...
i think if use lsd ...can get better timing woo..just my 2cents
I did my test on my car using rsm,best is 6.9 sec,average is 7.2 - 7.5sec,400m 15.5 - 15.8sec
Car = KE70 SVT+Bt ecu,4-2-1 extractor,custom trumpet,AE86 gearbox+LSD
14inch tyre,rear boot all empty,test done on evening
I did test on my fren Stock STD seg101 using the same rsm,best is 10sec,average is 10.5 - 11sec,test done at night
haha bro nnik.
non lsd gearbox also can slip la .LSD slip more geng onli.. haha..
i think the time can be improve.. after chnage tyre will try again.. haha..btw .. hope can get 7 ++ sec on my car..
hard to measure lerr...
engine same.....but car body different, rim size different....some use rsm. (only 1 driver),...some additional 1 person at pessanger side......result also different....
my SEG BT with 17"RIm , 10s calculate by RSM...
yo ~~ so fast u alll..
perhaps mine stock bt ..
none modification..
somemore auto..
hahaa
SEG AE101
20V BT (M/T)
14" tyre
Stock exhaust
thought u write down manual? suddenly change to auto kah? hahhaha
hahaha...soli soli typo..
changed deeeee soli soli...nothin how bout urs ar??
mine? not so fast lah...
estimated 8 sec around that. RSM. best is with two person, banyak "taik" dalam hahahahhahha..
to clock time and compare like this, need to be the same way of RnD.
rsm or other electrical devices. to be more accurate, got G-sensor for RSM. the error from wheel spin can be corrected using this G-thinggy.
my view: LSD should improve your time a bit. give traction during starting.
some minor2 things to consider:
rim and tyre size
fule (ron97 or ron100)
gear ratio and finale drive can consider as contributing factor issit? or more like .secret weapon.? hahahahhah
my car BT 5 speed manual wit 15 rim 195/55/15 and TRD plug cable and 2 guy more then 140kg in the car can get 9.++ wit twin muffler....
next time wanna take out all suff then maybe can get below 8....
