BMW drop in 1JZ
JERRY_VR4
JOHOR BAHRU
Hi zth member :
I've new project to haf a new car ...
A BMW E36 to drop in 1jz supra engine, but as i know 1jz got so many type from diff half cut , may i ask which kind is the best???
I found 1 1jz engine vvti single turbo , may i know is it the house power stronger than twin turbo? Which engine is more potential to highly modification? is it now still can approved by JPJ?
Supra better(the old type)... Twin Turbo inside...hehe..
Coz drive Pajero with 1JZ 2.5litre twin turbo from supra... can do drift in auto transmittion...very powerful engine...
Good Luck..
Get the wan from the supra or soarer..i think both of those also twin turbo..producing 280hp.:biggrin:
Yupp using a single turbo..hp is 280..but the torque is 378NM @ 2400rpm..compared to the normal wan at 362NM at 4800 rpm..not sure bout this..try google it up..cheers!
yeah, i'm also ask same question...is it can be approved by jpj ? anyone? I'm also thinkin to put rb or 1jz....
as i know,u need to apply 1st rather than transplant.
JPJ pass tapi yum cha a little bit le.. drop the old 1jz twin turbo le.. damn cun... seriously seremban now have more than 7 BM with 1JZ around and they are from 1 team..... imagine how fast there are...
sure can approve ahh dude?..heard from BMW to Nissan is definitely no go..
mine i chucked in RB25DET,until now haven't reg..:embarassed:
wow...salute la bro!
how come u never apply 1st then decide wanna convert or not?cant wait huh?
Can be approved but have to follow all the JPJ rules...
I have a fren pass from JPJ by using RB20 into his old 728 BMW...
Good Luck...:smokin:
wah...BMW's V8?wonder how much it cost?how many cc?3500?4000?
go for 4.0 liter la...
there are 3 different 1JZ configurations. here i have to tell you that both supra and soarer have different parts and not interchangable within each other.
example: radiator. as you know the 1JZ uses viscous drive rather than fan belt to drive the fans...that's why it's so quiet even with aircon switched on. both soarer and supra have different mountings and the water outlet/inlet.
ECU also different. Supra have no TRC while soarer got.
Engine : same one la but i never understand why toyota come out 2 different layout.
Parts: Supra more common than soarer. go for twin turbo la..easier to install and more response. no lag.
there...my past experience la...maybe now different already.
E36 wanna fit 1JZ...a tight one bro... but it should be awesome once you put it in. quiet, and powerful...especially auto. hehe. have fun
there u go... d miton has spoken...
5115: V8 = 6k for d 0.5 cut
1JZ-GTE: VVT-i vs standard
The 1JZ-GTE engine has been modified by the addition of an Intelligent Variable Valve Timing System (continuous wide range intake camshaft phasing control system) and a new high-efficiency turbocharger. The engine generates 50% more engine torque at low engine speeds, and turbo lag has been reduced by 50%, while allowing a 10% improvement of fuel economy.
summary:
1.) Low to medium speed torque has been improved while ensuring high power output.
2.) Turbo response has been improved.
3.) Fuel economy has been improved.
Maximum Torque (Nm @ RPM):
VVT-i = 378@2400
standard = 363@4800
:smokin:
Brother, i looking for 1JZ-GTE(Auto), Soarer Halfcut.
Drop me any contact ... Thank you.
but the runner said must only can drop in same model engine, BMW-BMW , nissan-nissan ..
i thinks still needed under table 1 ...:cheers:
But my fren do all the nessary things like taking approval from HQ at Putrajaya and do all nessary things without a penny cents of Kopi-o oh...
Puspakom side, need to kowtim a bit la.. just 50 bucks onli...:smokin:
