shiro...in kelantan u often see the sultan's cars kah?....heard he also has a number of supercar....
I wouldn't say not reliable, another one made slightly lower hp (250-260ish whp/280+hp on engine) without ITBs.. near similar setup (currently into it's second year, only minor maintainance stuff.), after all, it's running sleeves rated for 1000hp boosted setups, so no chance of cracking the sleeves. Currently not sure if the ITB contributes to the performance or not, but it is the only difference between the two setups.
But the engine can be considered reliable, but maintainance has to be done occasionally, but it's not that major, like needing to strip the engine or something. But it will come, that's the expense of pushing the engine to the limits when the an average(non-vtec) 2L only makes about half of the hp.The crank bearings will probably see more wear, but that depends on if the car is constantly abused or not. But naturally this engine does not use OEM parts, so it's rather sturdy, IMO.
Back to topic, I couldn't believe it at first too when I first heard it.
The torque output is insane on this one as you can see.
Now that I've got the chart, the rev limit is 9K confirmed, and as you can see, it wasn't just one run. This is the 6th and final run.
Well, a 2nd ITB setup coming soon, so we'll see how it compares to a non ITB unit, whether it's the ITBs or not.
No scanners 4 now, so you guys just have to be satisfied with crappy phone photos.
click to enlarge
the vtech point look like engage at 8k rpm n end to 9 k rpm
if this car dyno at MelXXum motorsports its not to believe so much from my experience i have doing compare between melXXum n jc asia at the same days different 30 whp n nothings have touch on the same setup
if more higher HP car dunno got more much different or not but this only experience from my self lar..
for my self HP on graph was no important the most important was respond or the car when u full throttle/part throttle respond to giving smooths driving
well, actually the numbers are after engine & ambient correction.
Still, anything above 250hp is good already :P
Well, due to owner's permission, I can only show dyno results, but no details, although I know them, as for the general setup, big displacement, big cams, 9K rev limit, ITBs.
And total cost should be well below the price on the new Civic type R.. lol. Probably about a bit less than half for the engine alone.
Dunno if the ITB's contributed or not, because it was never dynoed with a plenum intake, but the previous result was about 200 something hp only, and that was at 6K rpm limit before the gasket 'mampos'ed. So on hold for quite a few months, but it was quite a surprise seeing 200+hp at 6K without running a turbo when I first saw the chart.
Initially thought the cams were too big for the setup, but it seems to work fine in the end.
Obviously it's not a daily driven car.
click to enlarge
