Bro SRF,
Do we need 93t head parts for 1.8 mivec conversion? I thought we just need its block...correct me if i'm wrong. By the way for 93p putra or gti block is only rm5xx- rm6xx, labour charge hew hundred. I got quote rm1.5k by my frens mech for 1.6mivec - 1.8mivec conversion. (including belt + oil + etc) but then he didnt suggest me to upgrade my ecu... do you guys think that remaining OEM mivec ecu after 1.8 block changed will not damage the engine during high rev?
I think if you already have a 1.6 mivec blacktop why not just bore it out and use 82mm pistons and then get a full piggy back or standalone. I'm sure you'll see similar gains.
Stock 93 pistons with mivec head and ecu should get you 155 whp.
no need 93T head la when u want to mod to 1.8 mivec...
then if u want to use 93P block doesn't matter...but to me better get 93T engine block...it more tougher...
currently i'm using same conversation also...mivec head with 1.8 93NA japan engine block + flat 81 mm piston + OEM mivec ecu & wiring...already 3 years..
i'm very sure that my a/f ratio was too lean when over than 5k of the rpm...
but i'm not so worry coz i just driving my car like my old father...hehehehhe
u need to use piggy back or stand alone ecu if u want to get max power from your mod machine...
Well there's always a danger of having too high a compression ratio for your conversion. Using mivec pistons in a mivec 1.8 hybrid may not be best for your engine. You might be looking at a 12:1 compression.
They say you can use 4g92p pistons which are domed but not as aggressive as mivec pistons.
As far as over sized pistons go... get them and you better make sure your mech does a damn good job boring out your engine walls.
Just be sure when you do perform a Mivec 1.8 conversion you aren't surprised that your peak HP only comes in at 7000rpm.
how is your fc bro? if drive like normal like 70% highway and 30% town and mayb open mivec few times in a week? Mind to share how many km can you achieve? Mine if damn heavy foot all time whenever i cruse only can achive 260only.....
but normal drive can go 410 the max. Very concern that the fc will go worst after modification so i need to do some survey b4 going to mod my engine
if u using normal emanage then the tuning will be limited for mivec...
but if u use the emanage that got the variable valve timing thingy which is the latest emange then there is alot of tuning can be done on ur mivec engine...
Same low profile here :) I'm also using standard putra exhaust with 2" S flow piping and OEM air filter. when crusing car can be silent at low rpm but my engine sound will louder than my exhaust when cruising at high rpm. If you never tuned the ecu your mivec should be kick in from 5.2k rpm / 5.5k rpm. Try notice it when you drag ur car and sure u will hear your mivec scream at 5.2k rpm
LOL i'll ask my friend to provide dyno chart then...btw is a Mivec CK engine...terbalik version
actually the tuner is good dats y can tune the car so well...
