EMS Dyno Results
Re: Microtech Dyno Results
Wira GSR
1.Engine 1.8 Turbo stock engine
2.Turbo GT28 HKS
3.Microtech LT10s
4.750cc injectors
5.Stock Gearbox
Boost at 16psi
Wira VR4 engine
1.Stock engine with overbore 86mm pistons
2.Microtech LT10s
3.Injectors 1000cc
4.Turbo Garret GT30
5.264 deg Cam
6.Stock gearbox evo3
7.Turbosmart boost controller
Low boost 16psi
Good torque.
Perdana Evo engine
1.Stock Engine Evo3
2.Stock gear boxe
3.Turbo T04
4.Microtech LT4
5.HKS boost controller
Boost at 0.9bar
nice numbers, let me try digging for mine :D hehehe bt of cos lower laa
Aiyooo jink have a good power from their engine maa...Jink put la your dyno result.
N/A Result come on put it here.....Bro
My friend car wit gsr standart engine only use TD05 turbo, walbro fuelpump , wastegate, 560cc injector and SAFC NEO can get 346.7 hp wit 1.0 bar after tune by Mat Penang. Ur car use HKS turbo, microtech wit 1.6 bar only can get 305.4 hp ar bro ? :driver:
actually its very very hard to compare dyno sheets
its ok to compare dyno sheets of same car same dyno , before and after mod
but it really varies from one dyno machine to another dyno machine
especially the dyno brands , SAE correction values , etc
Dyno Dynamics , Dastek Dyno , Dynojet
My friend car wit gsr standart engine only use TD05 turbo, webro fuelpump , fuel ragulator, wastegate and SAFC NEO can get 346.7 hp wit 1.0 bar after tune by Mat Penang. Ur car use HKS turbo, microtech wit 1.6 bar only can get 305 hp ar bro ?:driver:
drax chip ecu+ td05 + 4g63t + 1.4bar gave me 301whp
after microtech and 20g , 346whp , tuned by abg penang (waiting for free time to go to toby/thomas for reprint)
currenty 0hp :P car no engine kekekekke
My friend car wit gsr standart engine only use TD05 turbo, webro fuelpump , fuel ragulator, wastegate, 560cc injuktor and SAFC NEO can get 346.7 hp wit 1.0 bar after tune by Mat Penang. Ur car use HKS turbo, microtech wit 1.6 bar only can get 305.4 hp ar bro ? :driver:
is it true that your friend car can get 346 hp?? curious. wheel hourse power??? very very impresive. but after all have to depend which type of dyno machine. alot of factor.
I have a feeling i saw somewhere in BOT topic, RSI is BHP not WHP,
hope someone can clarify :D , never dyno'd on Dastek before hehehe
Owner of dyno can Xplains?..why the dyno have a load and some dyno dont have a load system.All dyno is good.tuning is very important
Tips if u wan to tune your car on dyno.You have to put some information.
For Dyno Dynamic
1.Run 3k rpm and see the KMh and lock
2.Room Temp
3.Inlet Temp
4.Humidity
5.RPM
6.Boost or Vacuum gauge
And u can see the real WHP come out at the graf
YouTube - Dyno Dynamics High HP Video
Im not familiar with the other dynos
wawlauwe...good Hp tu bro..easy bro.take the graf and show to ppl bro baru bole proving bro...nyanyi kuat..the casset cannot laku bro...hehehe.now everybody want to see..selambe
kudos to KR Performance for bringing up dis kind of thread which is for me ,(and maybe other peoples) could gain info n knowledge with the mods being done..and as a reference too. as least with the base given, we could set a target when building up a motor. jz sum doesn't understand it..hmm..ok..jz ignore me..
Bro, awesome microtech dyno results. Good to members here for upgrade planning to management.:biggrin:
bhp= brake Horsepower...
WHP- wheel horspower...
refering to Newton law 3..both mean the same :biggrin:..Brake refer to HP at crank while wheel mean include losses through transmission or friction coefficient or etc..mean true HP..
:slug:
:slug:
BHP - crank hp
WHP - wheel hp
BHP should be higher than WHP :)
