{wts}talking Alarm At Price Rm138
ICE -In Car Entertainment
Seling Talking alarm system at price RM138 only,it is new,warranty 1 years,call 0162121767 for information.
please vist:
http://http://i130.photobucket.com/albums/p248/fofit/Picture040.jpg
ULTRA RACING{Call for Best Price}
GAB
http://i296.photobucket.com/albums/mm179/hugokajang/20080520815-1.jpghttp://i296.photobucket.com/albums/mm179/hugokajang/20080520816-1.jpghttp://i296.photobucket.com/albums/mm179/hugokajang/20080412590-1.jpghttp://i296.photobucket.com/albums/mm179/hugokajang/20080412592-2.jpghttp://i296.photobucket.com/albums/mm179/hugokajang/20081004309-1.jpg
{wts}tomohawk 2way autostart alarm
SEling it at price RM240 only,it is new n warrannty 1years,if interest,call 0162121767 for information
- Remote Engine Auto Start (Compatible to Petrol and Diesel Vehicles)
- Timed Start (The car can be set to start up at a specific time using remote real clock)
- 2000 Meters Control Range
- 2 x LCD Pager with Blue Illumination Light (Dimension: 5.5cm X 3.5cm X 1.5cm)
- with Melody & Vibration Alert
- Anti-Carjacking (Remote Engine Shut Down)
- Turbo Timer
- Remote Trunk Release
- Panic Car Search
- Reservation Mode
- Valet Mode
- Auto Central Locking
- Auto Window Closer (Require Module)
- Auto Warning Unlock Function
- Auxiliary Output for other types of sensor e.g. ultrasonic sensor (motion detector)
- Adjustable Shock Sensor included
LCD Pager display live status of the car: -
1.Hit or Impact on Car Body
2.Car Break In / Unauthorized Entry
3.Engine Running
4.Car Doors Opened
5.Trunk Open by remote control.
6.Real Time Clock
7.Turbo Timer Running
8.Alarm Status e.g. Arm or Disarm
9.Battery Indicator
10.Pager Control Range Indicator
GAB
{wts}alarm at price rm38
Seling alarm system at price RM38 only,new n warranty 1 years,if interest,call 0162121767 for information.
GAB
{WTS} DashBoard Carpet
Seling dashboard carpet at price RM80 only,,it is new,,,if interest,call 0162121767 for information.
GAB
{wts}steelmate talking alarm
Seling STEELMATE 838G talking alarm at price RM168 only,it is new n warranty 1years,,,if want install RM30,,,if interest,call 0162121767 for information.
RM250/GT-WING
http://i296.photobucket.com/albums/mm179/hugokajang/20080926296.jpg
GAB
Re: {wts}tomohawk 2way autostart alarm
GAB
Re: {WTS} DashBoard Carpet
GAB
Re: {wts}steelmate talking alarm
GAB
GAB
GAB
GAB
Re: {wts}14" steering
GAB
Re: {wts}alarm at price rm38
GAB
GAB
GAB
GAB
the alarm plays what sound... the normal alarm ka??
ICE MA Audio Product Selling Cheap.......
http://www.maaudio.com/assets/Image/banners/ma_header.jpg
https://www.zerotohundred.com/forums/attachments/158544.vB
MA Audio MA120XE
MA Audio Authorize Dealer
  • Competition Subwoofer
  • Features: 350W Rms
  • 700W Max Dual 4-Ohm Voice Coils 150oz
  • Double Stacked Magnets Mounting Depth: Mounting
  • Diameter: Optimum Vented Box: 2 Cu/Ft Round
  • Port Diameter: (2) 4” Square Port Area:
  • 25 Sq/In Port Length: 15.5” Optimum Sealed Box:
  • 0.75 – 1.25 Cu/Ft MA Audio
  • 1-Year Warranty
https://www.zerotohundred.com/forums/attachments/158546
MA Audio HK60C 6.5” Component Set
  • 100W Rms
  • 200W Max
  • Sensitivity 90.2dB @ 1w/1m
  • Frequency Response 30 Hz - 25 kHz
  • Mounting Depth 3”
  • Dual Amplifier Inputs
  • MA Audio 2-Year Warranty
https://www.zerotohundred.com/forums/attachments/158545
MA-M1883IX - MONOBLOCK
  • 1x400RMS @ 4ohm
  • 1x800RMS max @ 2ohm
  • Built in low pass xover
  • Full mosfet circuit
  • Bass Boost
  • SNR >90db
  • Distortion
(PICTURE UPDATED SOON)
MA M283ix
  • 2x100RMS @ 4ohm
  • 2x200RMS @ 2ohm
  • 1x400RMS @ 4ohm
  • Built in low,full and high pass xover
  • Bass Boost
  • SNR >90db
  • Distortion
  • 25A fused
https://www.zerotohundred.com/forums/attachments/158550
MA AUDIO MA-60.4iX
  • 4 Channel
  • 110W RMS x 4 @ 4 Ohm
  • 220W RMS x 4 @ 2 Ohm
  • Max Power: 1800W PMPO
  • Full MOFSET power supply
  • PWM Circuitry
  • 4 Gauge Power / Ground Connections
  • Full Selectable Crossover : High/Flat/Low
  • 4/2 ohm stable stereo
  • Variable Low Pass Filter : 50-250Hz
  • Variable High Pass Filter: 120-3KHz
  • Variable 12dB Bass Boost at 40Hz
  • Frequency response: 10Hz- 30KHz+/-3dB
  • Power Bandwidth 18Hz-22KHz
  • S/N Ration : 98dB
  • T.H.D: 0.02%
  • Chorme Plated RCA Jack and Terminals
  • MA audio badge on amplifier
  • Line out
MA Audio MA120XE - RM550
MA Audio HK60C 6.5” Component Set - RM550
MA-M1883IX - MONOBLOCK - RM650
MA M283ix - RM450
MA AUDIO MA-60.4iX - RM450
Contact - 012-701 1502 For more infomation Thanks......
BlauPunkt Head Unit Player
http://www.nine-eleven.com/images/blaupunkt_logo.jpg
https://www.zerotohundred.com/forums/attachments/158551.vB
IDC-A09 CD changer main features:
Five disc CD changer, DIN sized, compatible with all recent Blaupunkt aftermarket DMS equipped car radios
Suitable for mounting above or below head unit on double-DIN equipped vehicles
Can also be mounted in boot, under seat (with extension cable) or glove compartment etc., vertically if required
Advanced anti-shock, anti-vibration system
This aftermarket CD changer will not work directly with many factory-fitted radios. To ensure your installation will work correctly check with the Blaupunkt technical helpline on (01895) 838 880. A handling charge will be imposed for changers returned as being incompatible.
  • Disc naming capability (with compatible Blaupunkt receivers)
  • 1-bit Delta/Sigma DAC
  • Frequency response: 5-20,000 Hz (-1 dB)
  • Signal-to-noise ratio 100 dB (A)
  • Crosstalk attenuation typically 85dB, THD typically 0.005%
  • Will play quality CD-R, but not CD-R/W media
  • Dimensions 179mm wide x 52mm high x 184mm dee
  • CDs can be removed whilst another is playing
  • Slot buttons illuminated green if CD loaded, red if CD playing
  • Can be mounted at any angle
  • Complete with 1.0m connecting cable & full fitting / operating instructions
RM650
GAB
