PowerZONE'd cars!
Powerzone
TEST CAR FITTED WITH POWERZONE PRODUCTS
Test Vehicle
Car Regn. No: WHF 577
Make/Model: PROTON Wira 1.3GLi Aeroback
Year Manufactured: 1999
Engine Fitted
Engine Type: Mitsubishi/Proton 4G15 SOHC
Engine Capacity: 1468 c.c.
Engine Modifications
Camshaft: PowerZone high performance road formula cam (reprofiled from original camshaft).
Cylinder Head: 12-valve head custom ported and polished by PowerZone using original standard parts.
Cylinder Block: PowerZone blue-printed with fully balanced crankshaft, standard piston size, and using standard parts only.
Fuel System: Nippon Denso MDH182 injectors, standard 45mm throttle body, original Wira 1.3 ECU, standard fuel pump and fuel pressure regulator.
Performance[/b[
Max. Power Output (flywheel): 120.4 bhp (dynoed by Speedworks)
Max. Torque
: 137.9 Nm
0-100 km/h: 9.5 seconds
http://www.powerzone.com.my/images/testcar.jpg
Dyno Chart
http://www.powerzone.com.my/images/WHF577dyno02.jpg
© Copyright 2003 All Rights Reserved by NS Performance Tuning Sdn Bhd.
Have you guys done full makeovers for a Kelisa? What are the works, the gains and the costs?
Thanks.
Actually, we have not!
So far we've got the cams and extractor, but we'd like to do a full rebuild if there's anyone who wants it.
We don't do bodyworks so we'll focus on the engine.
The mods are:
1. Pair of hot cams
2. Extractor kit
3. Exhaust piping and silencers
4. Ported head
5. Engine blue-print and balancing
6. Fuel pressure regulator.
We don't have the exact cost involved, but a ball park figure hovers at RM5,500.
Yeah, we know. NA tuning costs a bomb (sometimes bombs are much cheaper!).
And would be beneficial to put in a fully programable stand alone ECU, costs around RM5K!!! Perhaps not. NA tuning is not like engine transplant, unless all the parts are second hand. Afterall, half cuts are totally used, right?
Yeah, I'm not really comfortable with swapping engines anyway. The trouble is just not worth it.
How advantageous is it to have the stand alone ECU versus without (just the mods). Would it be a marked improvement? Cons of going without it?
I'm asking because another 5k to fork out for the ECU is a bit tough.
Any alternatives?
BTW, I did notice that the Wira stated above is still using its original ECU.
Originally posted by Powerzone@Feb 25 2005, 16:26
The mods are:
1. Pair of hot cams
2. Extractor kit
4. Ported head
how'd u get the FPR installed? the kelisa fuel rail soenst have a return line.....! :unsure:
how much and how long per item would you guys do a kelisa for
1. camshaft
2 .porting
3. blueprinting and balancing
Any alternatives?
We don't have any improvement figures yet with a stand alone ECU, but this is just a recommendation after all the mods been done. So, can't say if it's worth the 5K.
Originally posted by tks+Feb 25 2005, 14:25 -->
QUOTE (tks @ Feb 25 2005, 14:25 )
--QuoteBegin-Powerzone
@Feb 25 2005, 16:26
The mods are:
1. Pair of hot cams
2. Extractor kit
4. Ported head
how'd u get the FPR installed? the kelisa fuel rail soenst have a return line.....! :unsure: [/b][/quote]
This is a more complicated process as it involves:
1. Modifying the in tank fuel pump to disable the built-in FPR.
2. Installing a fuel return line.
3. And fitting a new adjustable FPR.
Costly too. Extimated at RM500.
However, this mod is NOT absolutely necessary.
1. camshaft
2 .porting
Prices are:
1. PZ performance camshafts (pair) =RM1450
2. Porting=RM1500
3. Blueprinting and balancing=RM2,500 to RM3,500
can powerzone do lightening the crank shaft & balancing ? cost ?
Originally posted by Powerzone+Feb 26 2005, 13:28 -->
QUOTE (Powerzone @ Feb 26 2005, 13:28 )
--QuoteBegin-DimDimer
@Feb 25 2005, 14:35
1. camshaft
2 .porting
Prices are:
2. Porting=RM1500
3. Blueprinting and balancing=RM2,500 to RM3,500 [/b][/quote]
wow...sudah naik harga sikit ar! :D
i'm curious...at what point (for the kelisa) would we need to do the FPR mod?
We don't do crank lightening as this is NOT an accepted blue-printing procedure. Why?
The crank counter-weights are calculated by the design engineers (with sophisticated computer analysis) to produce an opposite and equal dynamic force to counter the centrifugal throw-out force of the pistons and con-rods so that the rotational components are fully balanced, both axially and radially.
Cutting off the counter weights will make the whole rotating components to be off balance and can cause premature bearing wear!
The balancing of the crankshaft including the front pulley, con-rods, and pistons altogether costs RM600 (parts taken out from engine).
Originally posted by tks+Feb 27 2005, 07:58 -->
QUOTE (tks @ Feb 27 2005, 07:58 )
@Feb 25 2005, 14:35
1. camshaft
2 .porting
Prices are:
2. Porting=RM1500
i'm curious...at what point (for the kelisa) would we need to do the FPR mod? [/b][/quote]
Usually when it's found that the fuel mixture has become too lean, by looking at dyno charts and plug coloration. But this occurs only after major mods like big cams (270 above), much higher rpm cut-out (above the standard redline), or a bolt-on turbo is installed. Mostly this done for rally applications.
@Feb 25 2005, 14:35
1. camshaft
2 .porting
Prices are:
2. Porting=RM1500
When after doing major mods like big cam (270 above) and rev cut increased to above redline, or bolt-on turbo installed, it's found that the fuel mixture is too lean across the rpm range.
Originally posted by Powerzone+Feb 26 2005, 13:18 -->
QUOTE (Powerzone @ Feb 26 2005, 13:18 )
--QuoteBegin-si|verfish
@Feb 25 2005, 08:42
Any alternatives?
We don't have any improvement figures yet with a stand alone ECU, but this is just a recommendation after all the mods been done. So, can't say if it's worth the 5K. [/b][/quote]
What are the pros and cons of having the stand alone ECU as opposed to sticking with the original one?
On top of that, what about noise and fuel consumption?
Lastly,
1. Pair of hot cams
2. Extractor kit
4. Ported head
What kind of increase in performance will be expected?
Thanks for your time.
With the stand alone:
Cons: Expensive. Needs good mapping specialist, i.e. tuner who knows what he's doing. Can't find one so far, not even in Sun Valley aka Sunway, lah.
Pros: Max out your engine potential, able to tune for any setup--hi-cam, rev cut, fuel economy, track use, etc. Switch to advantages of sequential injection, so many options, if one knows how to use it lah.
Noise? Not related to ECU mapping, I think. Fuel? Can be tuned for any appetite you want, or diet, ha!
The last question:
Honestly, we've not done one to this level and so, no dyno figure!
Cheers!
Thanks.
But, regarding the noise and fuel consumption, I was reffering to the mods without the ECU. How much different will it be from the standard car.
