where can buy & install piston for bot??
veilsideboyz
i plan to change piston to boOST HIGHER :d ...
anyone plss advice which shop :)
tqtq! :bawling:
tqtq! :bawling:
no engine stated
no boost level stated
no turbo stated
err if i start assuming it will sure be wrong
i assume
engine 0.3cc
last time boost 0.3 , now want higher 0.4bar la
turbo using td025
no engine stated
no turbo stated
i assume
engine 0.3cc
turbo using td025
0.3bar to 0.4bar no need to change piston
bro maybe u can try CA18DET pistons...size is 83mm. lowers compression a bit.....and quite strong too
nissan 180sx....u can probably get from a perfromance workshop or chop shop....no need get new....used will do.....new also got i sell but price not sure....under 1 k kua....
from my tuning for 3s celica turbo.stock engine can go up 1.8bar boost but u have change the injectors and fuel pump.
Bump: It's the 2zz engine?
get some info on the pistons on the net.....most importantly the piston pin bore size....compare both sizes....if 1mm difference or same then can fit......but u also have to look out for the piston skirt does not hit anything in the block.....otherwise you have to machine some part of the piston skirt......
0.6 to 1.0bar wat for change pistons? put in management will do thou.
vteckiller.......
RM2200 include install ?? :)
3sgte engine not same 2zz engine...
2zz is N/A engine.... 190 on engine...
3sgte already is turbo engine .. 280hp on engine...
oh ya...
if i change wiseco piston then boost around 1 bar or above.. by using turbo garret GT2510..
is it ok ??
i scare turbo will blow ....:itsme:
vteckiller.......
oh ya...
is it ok ??
without install of cos
rebore around 100-200
opening up ur engine by ur mech 300-1000+
hey! bro, u want to made ur car FLY ah...!
i support u !#turbo jet celica#:stupid::biggrin:
