can swap, the shaft is for G.box, not related to engine.
G.box housing will be the same.
yap it's the same, for cefiro gear box no change even u plug in 3.5l engine.
but remember to go together with ECU.
Sorry to say that u have choosen the wrg car for track for track use.XTEC,
Thanks for the welcome bro.
Only a few M/T's available here. I'm quite happy I got a manual.
Its actually a Track Day (Run What You Brung) to be held at Subic International Raceway on July 19.
I'd love to have the VQ30 but most available engines here from Japan are mostly VQ25's. (around USD700). Haven't seack en any VQ30 and VQ35 yet. pretty soon I'll get a VQ25 for extra HP and fuel efficiency.
Bro, 3.0l naik harga d coz more enthusiasts buy Cefiros nowadays and also this engine can be fitted to our bolehland Naza Ria with minimal mods. So we have to berebut with themroad tax?? ini semua boleh di aturkan. we are in bolehland dude.
3liter engine with ecu only ithink around rm 2~2.5k .
I ve seen a owner using 3l but paying the 2l roadtax but i dont how he did it .road tax?? ini semua boleh di aturkan. we are in bolehland dude.
SB3
Bump: Bro, 3.0l naik harga d coz more enthusiasts buy Cefiros nowadays and also this engine can be fitted to our bolehland Naza Ria with minimal mods. So we have to berebut with them
Bump: I ve seen a owner using 3l but paying the 2l roadtax but i dont how he did it .
sb3
G.ratio sure difference, if you use 2L box for 3L or 3.5L you get super pickup but you will burn more fuel for long distance travel.
You can compensate by changing bigger series tires, but your speedo reading will be off.
sb3
my 2nd ~ 4th gear laggy... possible it was for 3L
Bump:
change top part gua...
from 2.5l mod to 3.0l i see b4...
from 2.0l le.... teory can lar coz only top side some part different... any white mice?![]()
what u mean change top part:hmmmm:, i saw one is whole engine swap from 2l to 3l & engine cover 2l are perfectly fix in 3l engine. ++ a lit bit engravement down there![]()
swap engine = engine number changed = need to jpj = roadtax increase....
can swap only piston, ring, blok, head unit, valve, cam, shalf.... only not?
