Wat's the max boost for a stock 4g93t terbalik?
BUAHAHA... Just kidding...
U like high profile... But bro... Nowadays animals crawling on the highway... It's always wise to be a little humble on the road...
Ya..Agree ! Hmm..sometimes show a bit off at parking ^^ Since parking lot can't race...just can show off :biggrin:
Taiko.. the downpipe for t28 is 2.5" right ??
becoz I'm going to install soon...a bit nervous...:smokin:
Nervous like waiting for wife to deliver... Muahaha....
U can even go for 2.5"-3.0" also ok. No harm. Just to avoid the back pressure within the downpipe and get rid of the heat.
Yaya!! Waiting New WIFE !! HAHAHA!!
Ok ~ 2.5" is GOOD !! The bigger piping ... more no back pressure right ?
BRB..makan dulu..:biggrin:
Smaller downpipe, more back pressure.
bigger downpipe, heat and pressure goes away better.
Small = restriction ma....
Imagine u try to breath in from ur nose, blow out the air from your mouth through a straw...
Then, u try to breath harder, the blow out through the straw faster... Feel tired..?
Okie, now, change the straw to the "CHAN CHU NAI CHA" straw... BLOW!!!
How's the feeling..? Which one more pressure sustain in your mouth during the blowing process... Get it..?
Ooo !! I understand now !!
Smaller piping will more back pressure
Bigger piping less back pressure !! Turbo car love straight flow..
So the bigger piping you have...the more advantage you will get !! IS it correct ?!:biggrin:
Fuiyoh, this example is so good!..
---------- Post added at 04:16 PM ---------- 6 hour anti-bump limit - Previous post was at 04:14 PM ----------
bro, actually the piping depends on ur turbo+engine capability..if use too big will cause too much flow, thus the car feels sluggish..
ehdrian..How to know which piping should I put ?? :bebored:
Hmm..Or I think I just put same size diameter from IC to TB enough.. then turbo to IC follow the turbo inlet diameter ..:biggrin:
And... restriction will cause LIFT problem..!!
this wan u hv to ask abang speed2horizon ade..me also dunno wat's the correct size 4 ur car..callingABG SPEED2HORIZON[/COLOR][/SIZE]..
BTW..taiko how's your car ??
IF you wanna order piston let me know..we order sekali :love:
aiyo, dun call me taiko ler, not qualify ler..hehe..no money to mod la bro..just looking for a set of suspension currently, my current suspension too soft ade..
OIC..I dont play suspension ler :biggrin:
bro..you using td04..what's piping size ? From IC to TB and Air filter to turbo ??
2.5" right?
bro, suspension is very important for handling, don't just upgrade the power, power is useless without handling..yeah i'm using td04, stock turbine but i dunno the piping size, i just bought this car nia..not i mod myself wan..hehe
Wow..so good !!
Just buy the car..everythings got already...
Oh ya bro..I wonder know putra and satria gti same engine ??
THey both engine cr also 9.1 ?
Wow..so good !!
Putra and GTI CR 10:1 taiko...
high comp.
But I think the cams are different by a few degree.
oic..thanks !! :)
Taiko..lets share something..
I'm using HKS BOV type 2...
Which one you prefer actually... hks bov 1 or 2 ?? :biggrin:
I BOT almost 1 year... the hks type 2 make me sien liao...keke...
oic..thanks !! :)
Hehe... I thought I mentioned to u my car blow in... Hehe...no sound. Actually sqv sound almost the same. Cause uses diaphragm.
If u want something different, u can opt for those uses pistons like Sard r2d2, sheep dog, n etc.
Hehe..ok !! :)
It seen seldom people use sard or tial bov...:biggrin:
Taiko !! Today I just notice that my sard regulator meter show that below 20psi !!
Is it normal ?? Becoz last time i remember is above 20psi...hope can help !! :(
and..the lower cr you get...will kill vtec or vvtli function ?
Wow..so good !!
no la bro, the car just got 93t engine inside nia and a super soft adj absorbers, they rest is all stock..many things to with the car, gimme headaches..
I thought you have EMB ??
Hehe..now you are owner... you change the car to lenglui lol :biggrin:
Taiko..I got one wanna ask you long time ago...your cr is 8:5.1 ...
When you off boost...do your car hard to drive ?? Or wait the turbo spool...only feel more respond and power come ?:smokin:
wat's EMB?..my turbo starts spooling at ard 2800 rpm, so i can it's quite responsive..
