hi...any 1 can teach me?
penang
:itsme:i wanna up my l2s boost but....all my engine still ori....turbo also didnt change yet...who can teach me how 2 modifi my kancil up too 80-100 House power....>. :love:
this 1 always is my dream~100hp l2s kancil...
---------- Post added at 08:05 PM ---------- 6 hour anti-bump limit - Previous post was at 08:02 PM ----------
list out all the things need 2 put in...n need find who in penang here 2 help me done it....
pls...
all is the best~!
u can start by getting emanage 1st bro,
then upgrade your injectors & bigger turbine...tdo4.
my L2s friends usually go for Apexi neo+tdo4+injector+kelisa block bored to 1.0.. dont know hw much Hp la...
but..kelisa is 4 piston my l2s is 3 piston engine only can use meh?
emanage?blue 1 or ulti 1?
TD04 is use on pajaro 1?or the gsr?
which 1 nice?afc neo or emanage?
hi there john....
your target of achieving 80~100hp is on wheel (whp) or engine (bhp)? Normally there's 15%~20% power loss between whp and bhp (whp tends to be lower). Daihatsu quote 64bhp, so you might get 51.2whp ~ 54.4whp on a stock standard L2s (EF-JL)
Refer here http://www.cardomain.com/ride/474703 (you might want to skip to page 4... he just change to custom intake with open pod with exhaust mods and SAFC and he yield 83whp!!! btw, i think this guy zth oso
you can go mega-hp (120++HP) by swapping a bigger capacity block (850cc/1000cc) like carlmc sez... but i think reliablity can be an issue since you're using a NA block for a turbo application
IMHO, better you get:
  1. Do a dyno power run first to get your baseline whp reading
  2. custom exhaust... from downpipe (remove or gut the cat converter) to tip. 2" diameter all around is sufficient
  3. mod your intake either custom a CAI to your ori airbox or custom intake with open pod filter
  4. piggyback - SAFC 5 button is more than enough
  5. do a wideband tuning on the same dyno you do step no 1 and compare...
after doing all of the above, I think you can roughly the same as the guy shawn did... using a TD04 from a pajero might yield that magical 100whp that you wanted
as per the piggyback options...IMHO afc neo is a bit overkill since we can't tune air/fuel ratio on L2S and even L5 engines againts throttle opening since L2S/L5 throttle body sensor only sense open/close only (either 0% or 100%)
eManage is a different matter, combine it with ignition harness (to tune ignition) you have more tuning option...
my 2 sen only...
ive seen a kelisa came up wit a whopping 135hp on a dyno dynamics in millennium
turbine : td04 impreza rex
block : suspected (hehe..) the famous 1000cc block (his old block ler kot..)
management : emanage
tuner (the most important part, lol) : joshua thiran of millennium motorsports asia
i first tuned my 4efte, joshua was able to get 40hp more wit the std setup, on the same punishing dyno. what i suggest u do is, as to not waste unnecessary money, get an emanage first and tune it up. i recon ud end up wit at least 20hp more (considering ur engine is half mine, lol) compared to before the tuning. in my case, the tuner was the one who made the most different
Yup.... that would been better :adore:
pls...
all is the best~!
100hp was very easy to gain on 660cc block... as 660blok that is usual L2 block laa kan?
so, here, as your request to get 100hp, only a little (consider little) modification for me..
1) bigger turbo
2) bigger injector
3) bigger fuel pump
4) fuel regulator
5) a steady good clutch
6) piggyback
7) bigger intercooler (optional)
my old.. very2 old spec that im using gain 117hp
1) turbo = td04-09 (from pajero diesel ) = **RM450
2) injector = 240cc (from vr4 na or maybe perdana SE) ** RM100-150
or 295cc from charade gtti *if im not mistaken
3) fuel pump ( gsr, evo, sr20, rb20 *this is internal pump) or maybe u can use external such as walbro, bosch etc etc **RM150-300
4) fuel regulator **RM 200-350
5) clutch ( last time im using triniti racing clutch with custom double pressure plate ) **RM600 for clutch n double pressure
6) piggyback (im just using safc 1 bluscreen because no money to buy e-manage) **RM600 - 700 for safc
7) intercoller ( im using vr4 ) *optional RM1000 including stainless steel piping with samco
thats all my old setting... 117hp on 660cc @ 1.5bar.. ok laaa .. im very satisfied with this setup.. *tahun 2007punya cerita laa ni...
then after a while, air naik kepala, 246hp on 660cc ..
u at penang? owhhh, i can suggest u at this one workshop.. last time they use to drag at batu kawan... very nice pomen.. but at permatang pauh laa...
remember, great power come great responsibility! :biggrin:
aiya.. dont forget to have a good n bigger exhaust piping... 1.8-2inch is ok.. dont go to big later no backpressure pulak!
heed this man's advice... he's an old player in L2S :adore:
1) bigger turbo
2) bigger injector
3) bigger fuel pump
4) fuel regulator
6) piggyback
agree with danzeterna..
the proper way is to 'set the brain first' and then 'upgrade fuel supply' then it will be safer to upgrade those 'hot&hunger' things ... but if u want to get those hi boosting, perhaps u might want to think about installing metal head gasket ... use kelisa or kenari punya... cost around 80-130.. *not include labour charges!
papajahat & xtrewatermelon : wahh, mana ada otai... just sharing some experience...
consonar...
246hp on 66occ....damn...thats wicked man.....
ive seen alot of kancil with those huge turbines jutting out from the front grille...
definately not TD04 or TD05's.....could be AR50/60 but that was in kelantan le....
alot of illegal street racing there.
consonar...
yup.. really wicked... but somehow, the problem is gearbox... thats the limitation...
unless there were kancil ratios like honda ratios that easy to get...
246hp - td04lgsr upgrade skit,73mm piston,custom intake, gsr 390cc injector, banana, msd coil, and of course have to use standalone @ 2.5bar...
danz, budak2 kelate all crazy u know... even their 660 can tapau 1000t... gila meh!!!!
now pencen already... a lot of politic laaa in drag arena... :stupid:
danz how your court tribunal things?? settle already??
one of the fave turbine for those kancils turbo comes from the apexi RX series, confirm needs to potong bumper!!!!! feckin big!!!!!! gila kosaaaa!!!!!
err, uhuk.. uhuk.. emo sket, hehe..
i oso have drive kancil l2 ago. i think big turbo really not suit for ori 660 daily use kancil since even ori turbo of l2 already have turbo lag. if u put bigger turbo to reach 100hp at high rpm, but u low n mid range rpm hp = ori carb 660 kancil. really not nice to drive. once ori l2 launch sudden attack on u, u 100 hp sure ll lose to ori 64hp .but if u use 1000 cc block, then is diff story.
..Hehe...sell your Kancil and get a VW GTI...it solves all your problems then :P ... be safe and play safe bro...
rilekz la Jep ... get new kancil and build a new one .. not with ur previous cock sucking con man foreman ... come do at gombak :D
and always remember Panjang is Fakap ... Then u will be safe in drag scene ... kekeke ...
246hp = 660 ??? alamak .. tu dlu ... now 660 already 250hp++ ... kekeke ...
aku pencen sebab tak mampu ... :thefinger:
achieved 273hp on my kancil last time .. happy gila edy ... but now no money to do back :D
---------- Post added at 10:01 PM ---------- 6 hour anti-bump limit - Previous post was at 09:48 PM ----------
To TS - 100whp is too easy to achieve ..
1st - as told by my foreman ... L2s stock engine can withstand 1.8bar max with no problems provided ur fueling is sufficient ...
2nd - So cheapest way to do it is ... Change injectors / fuel pump / fuel reg / 2inch exhaust/ and a SAFC 1 should do ... and boost urself to kingdom CUM !!! :biggrin:
see the highest HP range .. might be close to 100hp or 90hp ...
3rd - still not satisfied ... go get a Turbo kacuk from Tong ... choices are - RHF4/Garrett ar 48/ TD04-09 ... choose wisely ... i would recommend the TD0409 ... u will save alot since its PNP ... only minor mods to the i/c piping and turbo fuel lines ... CONFIRM 100hp :D
thats for 100whp la ... no need change piston or intercooler :itsme:
gud luck :nurse:
