- Joined
- Dec 14, 2008
- Messages
- 4
- Points
- 1,501
Custom Carbon Fibre Dashboard Laminate
Custom Carbon Fibre Dashboard Lamination.
Auto Laminate is a hard coat technology that provides an enhanced scratch, solvent and chemical resistant surface that is able to alter texture and gloss levels on a part’s surface. This is NOT a sticker, it's a manufacturing process.
A large range of wood, steel and carbon fibre textures are available. It has the capability to form onto parts and components of different depths of form from flat inserts to complex 3D shapes.
- Updating look of old dashboard trim e.g. to carbon fibre, brush stainless steel or wood surface
http://2.bp.blogspot.com/_7NNJ2e7PMtM/SqWcTbER1QI/AAAAAAAAAMo/VeI3R5aaEyw/s400/e46cfint_coupe.jpg
Engine cover - Heat and scratch resistant
Here's a pictorial step-by-step transformation of an E46.
Before the transformation : E46 with wood trim
Removing the door trim
Removing the 3-spoke steering trim, tricky work as you don't want to set off the airbag!
All the piece out! 10 pieces in total, 3 dash, 1 gear bezel, 4 door, 1 steering & 1 gearknob
The same 10 pieces after the Carbon Fibre transformation
Close up of the 3-spoke steering trim, note how regular and even the finish looks
The finished product!
Close up of the gear-knob & gear bezel.
Call John 012 3068982
Click to Contact Auto Laminatehttp://autolaminate.blogspot.com/http://autolaminate.blogspot.com/
