fender bar need to drill hole?
speedking
Ur 3 point fender bar need to drill hole or not?
by the way is for a wira..thanks :)
no need drill hole bro. it fits nicely to your door hidge...and very firm and solid too.
i am also using a 3pt fender.
err, correction fstrader . you got it 50% betul, one end fix to door hinge, the other end have to drill 2 holes if i remember correctly.
fix the door side first, close it properly, then drill hoels for the other end and screw, tight.
better get someone who got experience to do it. if not door cannot close properly.
Wah, can weld directly?
In my car, I got two holes drilled for the forward arm of the 3-point bar.. that portion sits between two steel sections of the car body. Seems like the front part of the 3-point bar ties the two sheets together..
How to weld it directly? If the bar is welded on, do we need to weld that two steel sections also?
just weld the third point only... the other two side no need weld...
just asking.....if now i buy the 3 point fender bar for my new saga... next time when i sell the car...can i transfer it to my new car...say perdana or vios?
cannot.. coz is different..
thanks man...
dunno whether to mod my lmst or not.... coz so far not planning to get new car yet..
maybe in 3 years time i am getting.....hehehe....
just get the fender bars la. don't drill holes, just weld the buggers on. ur cornering will be freakin good man. :) i welded mine on and no other bars except the anti roll bar (stock) will give you real good feel.
yes.. u can try fender bar first...
Calvin, how much do u charge for welding the bars on? Mine is already installed, but would like to change from the bolt-on, to weld on for the point on the fender. Mine's a 2-point older model.
just wanna ask, when u weld the bar to the fenders, i sssume u weld on the front part, the other 2 parts are clamped together with the door hinges, so how to remove next time, if wanna change doors?
cheers
around RM60 la... need to open the fender la....
cheers
just install the third point only.. the door there cant weld...
