Gear Oil
Wayward
Penang, Malaysia
how often do people change the Gear Oil ?
apparently, Toyota service centers are so fukked up,
their policy on brakes, gears and power steering is :
ONLY change when KONG.
statistics show : 80% of accidents are caused by faulty brakes, due to corroded master brake pumps.
anyhow , how often should somebody change their gear oil?
Wayward
if u want the best performance on shifting gear better follow the booklet of the factory recommend........ gear oil 90 or 140 or 75-90w or LSD 90 most of the gear oil is suitable but hv to look in to the grade now is GL5........ 20000km is too fast lar gear oil can use up to 40000km but depend .. pls dun let it dry if not your life maybe dry too..... get mean???????????
depends la my frined.........
dont fuck up the toyota services centre....blame your self.............why dont take self inisiatif ( malay word huh )kekekekekek........to your self......minyak hitam gear oil all kind of that u can learn and one day try to DO IT YOURSELF ( NIKE )
kekekekekekkeke...............
yup can be done by yourself la....
for standard stock engine better change the engine oil after 10,000km for performance engine change at 5,000 km.....
break pad.......kekekek........this want if got bunyi already that try to feel at the brake pad whether it is finish already or what......can feel one kekekekekkekeke
gear oil..i usually change after 80,000 kkekekekekekek
thank you
i change my gear oil every 40,000km or so ... which is approx once a year laa .. doesnt cost very much maa ..
brake fluid oso i flush out and 100% refill once a year .. dont want those water vapour trapped in brake fluid to jam up my brakes when running really hot .. :D
i changed my gear oil between each 25-35K KM.
