tribellizard_6227 said:first of all did u do your intercooler piping and upgrade to bigger intercooler?if not yet better do it...better cooling system...!
second of all better u install in oil cooler...it helps alot...less oil leaking and all...!
then only u go for bigger turbine...injectors...fuel urgrade and all...
timmy said:if u have extra time let's catch up and discuss. Im also using GSR but still stock
gti[GSR] said:hmm to change turbos, da flange of td05 on da top has to b redone, n dey will bore da hole bigger to fit da exhaust manifold... its da flange work onli...
den wif bigger injects n fuel pump, it'll bs uffiecient... den tune it wif piggyback...
chrissgsr said:ur welcome fren, PM me for your contact number..![]()
kuyeen said:HALO THERE...
juz asking..do u still use standard bov...the black plastic 1.
or what type or brand u use.....
ur i/cooler also....how big...
Give me ur contact number?zack_ said:me also used stock gsr on my car. maybe we can met and discuss to gain knowledge on gsr engine.
