[HELP] on AE111 SRS Airbag Light
CorollaGT
Malaysia
The airbag indicator didn't shut off after engine started. I already disconnect and reconnect the battery terminal for 5 min to reset the ECU. But problem still occur? Any boby can help on this?:cry_smile:
Thank you
check ur SRS airbag cable....c whether it is unplug or loose liao .... cos it wil cos the light on ....js my experience hehe.
TQ runx608 for your replying
I already check the SRS impact sensor [yellow connector] on the L/R seat belt modules. It is seen OK no loss. But, i haven't check the dashboard yet. Any idea where is the spiral cable located?
TQ
Found error code 31 = Airbag center sensor malfunction from friend diagnostic scanner. Center sensor stuff located on lower part of dashboard. Hope it is a cable connection problem only.
happen to me also
what had u done?
same problem here.... but just left it... looks cool!! but not sure if its risky
New 12130 SRS ECU will cost RM 2,300+-. I manage to get chop shop unit from mudah.my. It cost RM 170- only. I been searching for 3 years plus for this rare stuff, you can try your lucky on online auction etc, ebay, mudah.. or look for fellow who brought AE111 halfcut for engine conversion.
It's a broken spiral cable. Located behind the steering. You also will lose the function of the horn when this is broken.
wow
so expensive
for the time being
i already unplug the airbag device at my steering, scare suddenly deploy
