Need help on my Woofer and Amplifiers
ivanz299
-Bro i got 1 kicker solo-baric L7 10" DVC (600 watt rms/ 1000 watt peak) and 1 RF 800a2 2ch amp (2x 200 watt rms/ 1x 800 watt rms bridged).
-So can anybody let me know....
http://www.kicker.com/Solo-Baric_L7
http://ampguts.realmofexcursion.com/Rockford_Fosgate_800a2/
if u can check again with the amp's manual, if there is a raint at bridged mono @ 2ohm. from the website it only shows bridged mono @ 4ohm, so for a dvc sub, u can only run it at either 2ohm or 8ohm only. usually if its not published mono @ 2ohm that means the amp is not stable at 2ohm. so kenot la bro, can only run it at 8ohm which will be underpowered for your sub. if u still want to try 2ohm, u risk damaging your amp. so either u sell your sub and get a 800W SVC sub, or sell your amp and get one that can go down to 2ohm and give 600W
Bro can i use 1ch x 200w rms for 1 coil and 1 more ch x 200 w rms for and other coil ? is it working ?
kenot, either amp or sub, one will rosak, but there will still be sound la, just asking for trouble only..
Thks bro normally dvc woofer they will connect parrellel or series ? With one is better ?
series u get 8 ohms, parallel u get 2 ohms, so all depends on the power available from the amp at those impedances, and what power is your sub rated at...
