Advantages:
Better airflow in terms of capacity and smoothness of the flow
Will increase response
Turbo kicks in better due to better exhaust flow after port and polish
Disadvantages:
have to be done properly. If one of the port is not even, it's like slow effect poison. It'll damage the internals slowly.
Wanna feel difference, just sand/grind off the casting line at the side of the port...
how many hp increase if PnP???
I was wondering.. What is the 5-angle valve job??
Which part would be ported n polish to gain highest efficiency?
Sorry intrude your thread bro..![]()
Aiks... depends on how much u port lor, and how well the porting and polishing job is done lor.
Interesting question. Cylinder ports flow better with a fancy four or five angle valve job. If you look at most standard valves there is only one contact point all the way around the valve face that actually seals on the valve seats. The width of this surface in multi-angle valve jobs is just as it sounds. Instead on one 45 - 46 degree angle. the valve will have two to three additional angles toward the valve stem under the valve head to smooth out the intake flow of fuel and air into the combustion chambers. there also may one to two additional angles above the sealing surface of the valve for the same reason.
But which expert in malaysia can do this job nicely. That's a question to consider.
THeory is simple. Smoother flow, better engine efficiency. Procided done correctly. If not a bench flow test, at least a "buret" volume test.
:hmmmm:.... :slug: OOo so thats "angle job"
Powerzone @ NS Performance claims in their ad "professional PnP job" but nt sure la...
Where is matspeed located actualy ?? Dont know la.. hehe
Is it true dat a hi ported head makes the engine more prone to wooverheating ??
What grade sandpaper to use to smoothen the casting? Can we actually sand the port till it smooth out/mirror like DIY..
