Latest S90 CT9A Evo 7-9 70mm Oversize Throttle Body .
Start selling at Early July
The S90-Racing Throttle Body is the Breathing Point of your engine. With
a Larger Oversized Throttle Body, you can supply as much Air as the
Intake Manifold demands. Whether you have a set of Aftermarket Cams,
Supercharger, Nitrous or Turbo, Oversize Throttle Bodies will deliver
More Horsepower! Oversize Throttle Bodies work well with Fuel and Air
Upgrades. Use of a High Flow Air Intake is required, as the opening is
larger than the Stock Intake Piping. Match Porting your Intake Manifold
will help Maximum the Larger Throttle Body Diameter.
Most companies simply bore out the stock throttle body and change the
Butterfly. Not S90-Racing! S90-Racing Throttle Bodies are made from CNC
Billet Aluminum AL6061 and are a direct replacement for the OEM Cast
Throttle Body. A Special Billet Throttle Blade & Shaft made from
AL7075-T6 is included to increase Full Throttle Response and
Acceleration, especially installed at Force Induction engine. AL7075
material can stand for highest boost pressure to 3 Bar we tested , Both
side of the shaft was comprise of Branded Ball Bearing to put out the
best respond. You will need to reuse your stock Map Sensor and TPS.
These can be reused from your stock throttle body. We have our own
Design & never copy from any other's Manufacturer .
Please Contact :
RS one Auto Parts
No. 35 & 37 , Jalan 3/33A, Batu 7 Off
Jalan Kepong, 52100 K.L
Tel: 03-62777768 / 62777325 / 017-8922633
S90 Racing
[email protected] / 017-7791517 Vincent Teo
RPW (Australia) Dealer
http://www.rpw.com.au/shop/index.php?page=shop.product_details&flypage=shop.flypage&product_id=1682&category_id=169&manufacturer_id=0&option=com_virtuemart&Itemid=31
Bump:
Bump:
Bump:
Please Contact :
RS one Auto Parts
S90 Racing
Bump:
Bump:
Bump:
