Save Monthly Electricity Bill Up To 30% !!!
All Other Stuff
Carrera
SP/BM/PG/BW
Features:-
Easy to use, plug into the nearest power point from the Main Switch Board & turn it on.
•One unit will work on whole house circuit
Absolutely legal
Immediate results on your first month electricity bill
Rapid return on investment
·Safe to use and maintenance free. No wiring
·Reduce electrical overheating
·Improve efficiency and power factor
·Surge and brown - out protection up to 400 Volts A.C
·Reduce waveform distortions and improve harmonies
·Earth friendly
·Power on LED indicator
·Tested by Productivity and Standards Board (PS:cool: & Sirim (Malaysia)
·Suitable for use in : houses, condominiums, apartments, shop lots, restaurants, offices, etc
Retail Price RM250 (MS188) - Suitable for below RM200 monthly consumption
Retail Price RM300 (MS388) - Suitable for above RM200
monthly consumption
Promotion Price :- RM 199.00 Only
30days money back guarantee!
Term & condition apply.
how it works?
Power Saver Technical Aspect
There are two components of power: reactive power and working (real) power.
1) Reactive power (kVAR) is used to create EMF in the inductive loads in your home and business.
a. This power performs no "real" work.
2) Working power (kW) is the power that performs the function of the load, i.e. turns the drive shaft.
When these two components combine, it formulates Apparent Power (kVA), the total power, which the load consumes. Apparent power is equal to the square root (sqrt) of kW2 + kVAR2. Power Factor is the ratio of working power (kW) to apparent power (kVA). In other words looking at all the power that a load consumes, how much of it (percentage wise) is used to perform the real work?
http://i11.photobucket.com/albums/a199/gelcandles/howitwork.bmp
Obviously, the lower the power factor, the lower the ratio between the apparent power and the working power, the more inefficient the load is. The Mini Sun Power Saver improve the power factor by reducing the amount of
reactive power (kVAR) that the load draws from the utility company. This is
accomplished by supplying the reactive power locally at the load by the use of
capacitors. Capacitors store the reactive power (kVAR) needed for the creation of the
EMF within the inductive load. As the motor operates, this reactive power is "pulled"
and "pushed" to and from the capacitors by the motor. In simpler terms, it can said
that inductive receivers (motors, transformers, etc) consume reactive energy, while
capacitor (capacitive receivers) produce reactive energy. Therefore the amount of
reactive power purchased from the utility company by a power factor optimization has
been greatly reduced, or eliminated.
How it works:-
All electrical supply is subject to surges from time to time, which result in spikes or parasitic peaks that cannot be used by your appliances as working power. These spikes simply consume electricity to no benefit. Worse still, they result in overheating, which shortens the life your appliances and wiring, and in extreme cases can cause burns, blow outs and power cuts.
Our Power Saver uses a capacitor system to stabilize the flow of electricity. It reduces the spikes in the supply, protecting against surges. The system improves the power factor of your electricity and reduces your electricity bill by on average 15%.
One Power Saver will work on the whole circuit in your building. Our field testing for a typical home consistently show that the Power Saver will save 3 to 4 kw per day, based on electrical consumption of 30 kw per day. The amount of savings depends on a few factors, such as the types of electrical appliances, the time they are in use and the location. Places near to shops, restaurants and light industries, where the voltage supply is unstable and fluctuating will see higher savings. Where voltage supply is particularly unstable, the Power Saver can reduce consumption by 30% or more.
The Power Saver reduces the reactive power generated by inductive loads. This improves safety by reducing the overheating of electrical wiring. It also extends the life span of your electrical appliances. The Power Saver is made in Malaysia, and has been tested by PSB (Singapore) and checked for compliance with EU standards.
Return On Investment
 Based on RM200.00 Retail Price
 Your average normal electricity bill is RM200.00
 With a 25% savings, your monthly savings is RM50.00
 By the 4th month, you would have achieve your return on investment.
 On the 5th month onwards, you will be saving RM50.00 every month Indefinitely.
Bump!....
How it works:-
power saver which uses a capacitor system has reliability issues. The chip system offers better reliability..
