Sony ES XM-7557, 5 chl amplifier amplifier
ICE -In Car Entertainment
finhaz
For Sale, Made in Japan, Sony ES XM-7557, High End 5 chl amplifier for RM1500 negotiable
If installation by Megasound Auto Acc., Subang Perdana, goods are covered by a 1-month warranty.
Brand new cost me RM3+++ last time
Please visit website for further info ;
http://www.crutchfield.com/p_158XM7557/Sony-ES-XM-7557.html?search=sony+xm7557&ssi=0&tp=115
One look will tell you this amp is something special. But the beautiful exterior of the XM-7557 multi-channel amplifier only hints at the technological innovations within.
Separate high-current MOSFET switching power supplies (for input and output stages), Non-Negative Feedback design, extra-large MOSFET output devices, high voltage/high current switching (for stability down to 1/2 ohm in stereo), discrete differential inputs, low boost control, and direct mode are the technical names for some of the features that Sony engineers have built into this amp. But, to put it in plain English, you can expect clarity and dynamic range like you've never heard out of a car amplifier.
Details:
-90 watts x 4 + 280 x 1 at 2 ohms
-180 watts x 2 + 220 x 1 in bridged mode
-non-negative feedback design for superior reproduction
-high-voltage/high-current modes
-single-ended push/pull design for stability at 1 and 0.5 ohm
-discrete differential inputs for reduced noise
-dual power supplies
-regulated input power supply
-MOSFET output power supply
-high current MOSFET finals
-selectable low-cut (subsonic filter) 7Hz-40 Hz with selectable cut and boost (0-10 dB)
-103 dB signal to noise ratio
-3-way protection circuits
-front and rear channels stable to 2 ohms (90 watts RMS x 4)
-subwoofer channel stable to 1 ohm (280 watts RMS)
-continuously variable high-pass/low-pass crossover (50-4000 Hz, 12 dB/octave) --independently selectable for front and rear channels
-continuously variable subwoofer crossover (50-200 Hz, 12 dB/octave)
-2 x 30-amp fuses
-25-1/8"W x 3-5/16"H x 12"D
If interested please contact me at 012-2143206 .
Mat
