Test Cd Player At Home, Sifu Pls Help
IceBikers
Hi, my fren had a old cd player which didn't use it for quite a while after he changed the new one..
so i would take it home and test it..
how shud i wire the cd player up?
what can i use as transfomer? pc power supply? handphone charger?
pls advise with details.. thank u
pc power supply can use , coz it's ouput 12V , yellow colour is 12 V , and the black colour is 0V (ground) , but i think u use AT type is better , coz more easier to setup.
what is AT type??
and comp power supply has 3 color wires which are red yellow n black.. how to connect?
my advise is dont use pc power supply... not enough power thus will burn your stuff.... becareuful, use a AC to DC power supply...
PC PSU output 12V around 5 amperes (min), cd player need 3 amperes only , i think should b ok. if use amp then connot already.
correct me if i m wrong.
[snapback]902519[/snapback]​
a normal pc power supply 12v will be around 10A to 15A ... wouldnt it be too big?
