I just got this TRD cables from chop shop. Just wanna know if the only way to know if they are working is just to plug in a running engine? I know multimeter won't work because resistance too high. Any other way to test the cables? I know the other way is ignition coil, cable and plugs wired to battery. Stone liao.
And the cables indicade number 1,2,3,4 on each one. Do they carry different resistant levels? I asked this because i remembered Levin818 and EFN did said something about different levels from the same set of cables (stock ones). How do you measure it? This is purely for my info not for some secret project. hehehe.
I have seen many selling the cables without the primary (from coil) cables in a set. Would there be any problems (misfire?) if running such setup? The cables can work for 16V and 20V right?
, would like to enquire the cheapest replacement for the stock turbo
