- Joined
- May 8, 2006
- Messages
- 65
- Points
- 1,506
wat is the usage of air fuel ratio?? and the function of HKS AFR....i have a hks air intake....is it best to have HKS AFR device / or not?
Dino@Casper said:air fuel ratio is not usage.. its a guide of your fuel n air mixture.... the normal ratio would be 14 air molecule to 1 fuel.. thats about the normal ratio during lower revs and lower loading.. as the loading increase normally we would have to lower the air fuel to prevent knocking
nitrus said:Oh!! so thats called 'knocking' ? when my car idles, when the load of the fan comes in, the RPM will drop around 200 ... then my car will slightly vibrate n i could hear some sound in the engine bay, i think this is the 'knocking' u're talking about .... is it bad? anything i can do to overcome it? tnx dino...
escaflowne said:this should be ur idling problem that caused the knock.You can hear like metal marble dropping on the floor sound tak tak tak tak..that is knocking..for the example,grab a diesel engine and listen to the engine.You can hear the speacial tak tak tak tak sound.For diesel engine is normal but for our engine it ain't normal.Knocknig actually is precombustion(if i am not mistaken)..Mixture didn't combust when the piston reach the TDC,maybe halfway to it and it combust.Cause excessive vibration and result to the sound of knock.Can be very loud or vice versa,try to rev all the rpm range to listen to the engine sound. Either adjust ur ignition timing or use higher octane fuel to fix this problem.
prodigy said:Speaking about 'knocking' sounds, when you hear a tak tak tak sound during idling, it could also be the tappet adjustment. I had quite bad tappet noise and i thought something was really wrong will i sent to the mechanic and he sort of adjusted it. Now its fine. Don't ask me what tappet is, the mechanic just told me so.
R34 carbon monitor from Duke Racing japan
