WTB : Supra 2jz-gte injector
3scamry
pj
Hi .. anyone got 2jz-gte injector for sale ? ... thanks ....
woooh mate... you sure you wanna go that way?
ever think of st205's injector ? it's 540cc if not wrong, or else get Sard 810cc, it cost les then 1k. other wise, it's a hard way to control fuel even with after market ecu though... unless you're not using for daily drive....
Bump!
hi ... GT4WD .... isn't supra injector 550cc ? ..... so st205 is 540 cc ? .... issit direct drop in replacement for st185? .... thanks ..........
injectors are either side feeds or top feeds.. which one are yrs?
hi all there... any idea where can get st205 injector he he he... i also want for my st185..... cheers.....
Black is correct, it's either side feed or top feed. ST185 it's top feeded.
ddr3/3scamry - lots of our 3s-gen member are looking for ST205 injector, but it's not easy. other alternative, 2JZ injector with 550cc...
ST185 - 450
ST205 - 550
1JZ- 450 (JDM Ver), 550 (US Ver).
2JZ - 550, not sure on version.
ddr3, which part of penang you're in ? i'll be heading to penang later on till next wednesday. drop me a call 012 616 8099.
Cheers !
now at kluang bro gt4wd.... actually my mech try b4 using 2jz injector on other project car but its seem running smooth when idling but once boost it up the air fuel meter showing lean... reason maybe too fine the injector injected the fuel n 2jz injector my friend last time selling to me rm250/pcs...
woooh.. far far away, bro ~
no worried, we have member from kluang also, but his at p.j now... hehehe
well, i cant really tell the performance bout 2JZ injector, but if i'm going for performance, i'll go for after market items, most of them are tested at hi output monster. or else you can check out hte RX7's injectors, i did some reseach on it before, but the data its not wiht me at this moment.
cheers
sorry to interrupt but would like to share some info that the 2jz injectors are very tricky... the japan spec 2jz gte had d injector size of below 500cc while the US spec 2jz gte is 550cc... the way i recognize them is by the injector socket... those grey colour are the jdm one and have capasity or below 500cc while the US spec is purple in colour... i found out this when i changed the wrong 2jz injector to my 1jz last time...and got the answer when i take my injector for injector cleaning where we are able to see the injector capasity there...
