-[WTS]- 4G92 Mivec Gear Box
justlikeu
Subang Jaya
i jus helping my friend selling this gear box
price can be NEGO
call owner
for better price
4G92 mivec complete set gear box :
-gear box
-drive shaft
-clutch
-flywheel
-gear shift
-pedal
details :
this gear box is different from other 4G92 mivec gear box,because owner had modify it
this gear box have more pick up
5th gear final
is 4.5, for other normal 4G92 gear box is only 4.1
at 5th gear 3500rpm with 100km/h, for other normal 4G92 gear box 3000rpm with 100km/h only, which means pick up is better and faster
this gear box top speed 235km/h (owner tested), still can go higher !!!
reason of selling : cause owner upgrade to LSD GEAR BOX
for more information kindly contact : 017-3287373(james)
SERIOUS BUYER only... THANKS
justlikeu said:
i jus helping my friend selling this gear box at RM2500 !!!
price can be NEGO
call owner
for better price
-gear box
-drive shaft
-clutch
-flywheel
-gear shift
-pedal
details :
5th gear final
is 4.5, for other normal 4G92 mivec gear box is only 4.1
at 5th gear 3500rpm with 100km/h, for other normal 4G92 mivec gear box 3000rpm with 100km/h only, which means pick up is better and faster
Bro,
I guess if u dunno much about mivec gearbox, y don u go to www.google.com n type in mivec gearbox so tat after u get the answer only u give details here!
mivec final drive is 4.592 sometimes ppl round it up to 4.6 so its easier...every stock mivec gearbox will have a final drive of 4.592..If u say 4.1 n ur fren mod it to 4.5 then its not an ori mivec gearbox...so pls check with your fren who is selling tis gearbox....No offence...juz wanna let u know more bout mivec gearbox!
i dont know what are you trying to show. transmission spec from 1.5 Mivec (Colt) ?
But you're selling a 4G92 Mivec tranny. i see no different from any other normal 4G92 Mivec gearbox if the final drivce is +- 4.6
You might need more googling.
2.5K? good luck on your selling.
bro... how i know wor... i jus the MIDDLE man le... the price is he set for me wan... i jus HELP him!!!!!!!!!! thanks anyway... = )
Actually u know or dunno wat u r posting?4G92 mivec is a 1.6 dohc mivec while u show me the spec is for a 1.5?so r u selling a 1.6mivec or a 1.5mivec gearbox?Ppl give u advice some more show ur temper..tis is d problem v kids nowadays...don accept what old ppl say and in the end only regret..haihz
means u are old man? hehe... i saw the final drive got 4.1 den i ma put la... din really see the cc also... since when i show temper? if i show i wont say thanks and so on... i did listen to the advice, if not i also wont take the trouble to go search for info... wat for i will regret? i din get to earn also... or ur regret means cuz i post wrong... den i regret now lo... @@ thanks...
sorry for posting the wrong info ar... i will try to find the correct info... or try to update from my fren... being middle man is not easy!!!!! @@
guys... let share... to count final drive... use differential gear to divide the ring gear... mivec one is 67/15=4.466... normal 4G92 gear box is 67/16=4.187... so do u get wat i mean? count already only come and talk pls...
cooljas... pls go get one mivec gearbox open it up,count and do the maths... thanks...
Can fit to 4G92 SOCH (1.6 XLi) onot?
just want to share...seems like easy to calculate the final drive...that final drive calculation like for honda gearbox bro...for mitsubishi there was another way...
there were 4 gears need to be calculate...
differential gear,output shaft ( 2 gears ) & 4th gear at intermediate shaft
4G92 or 4G93 - (A) differential/output = 67/17 = 3.941
(B) output/4th gear at intermediate shaft = 34/31 =1.096774
Then final drive = A x B = 4.322
4G92 MIVEC
- (A) differential/output = 67/16 = 4.187
Then final drive = A x B = 4.592
