Infinity Basslink II with Basslink 4sc
Basslink II with Basslink 4sc for RM1800.00 price negotiable.
Basslink used for 6 months only! Still under warranty! Ori stuff from TrioAuto
All in very good condition!!!!
Please call or sms: 012-6366619
[FONT=Arial,Helvetica,sans-serif]BASSLINK II
250-Watt Powered Subwoofer System[/FONT] [FONT=Arial,Helvetica,sans-serif]Specifications
[/FONT][FONT=arial, helvetica]MSRP U.S. $:424.95
Power Output:250 Watts
Frequency Response:20Hz – 320Hz
Variable Bass EQ:+3dB to -6dB at 45Hz
Variable Electronic Crossover:32Hz – 320Hz[/FONT]
[FONT=helvetica,]Owner's Manual for:
• BassLinkIIOMrev9-23-05.pdf [/FONT]
[FONT=arial, helvetica]Expansion slot for BassLink® 4sc amplifier module. This module adds four channels of full range power to the Basslink II allowing for upgrade of the entire system.
Remote bass level control included.
The BassLink II incorporates several new Infinity features and technologies. First, the 10" subwoofer and 10" passive radiator are square. Infinity's goal was to maximize cone area and extract every last ounce of bass output out of this modestly sized housing.
BassLink II can be mounted vertically or horizontally thanks to its unique mounting system. It provides user-adjustable input sensitivity, crossover frequency and bass-boost, allowing its performance to be optimized for any installation.
BassLink II features a 250W Class D subwoofer amplifier, providing all of the horsepower needed to drive the 10" subwoofer to fill the largest of SUVs.
BassLink II can be expanded to power an entire vehicle audio system using the soon-to-be released BassLink 4sc amplifier module, which delivers 4 channels of real power. The BassLink 4sc docks right inside of BassLink II and shares common power and audio conntection, allowing you to add the module and simply run new speaker wires to the front and rear speakers. The BassLink 4sc also comes equipped with Infinity's phantom center channel control. This allows you to really dial in the image to optimize performance of the system. The BassLink 4sc even comes with a setup disc to help you dial it in. You will want to share this feature with your friends for sure.[/FONT]
[FONT=Arial,Helvetica,sans-serif]BASSLINK 4SC
Multichannel Amplifier Expansion Module for BassLink II[/FONT] [FONT=Arial,Helvetica,sans-serif]Specifications
[/FONT][FONT=arial, helvetica]MSRP U.S. $:$229.95
Power Output:50W x 4[/FONT]
• basslink4sc_OM.pdf [/FONT]
[FONT=arial, helvetica]The BassLink 4sc is a 50W x 4 power amplifier that slots loads directly into the BassLink II. Coupled with the BassLink II, the 4sc will deliver real power to your front speakers and rear speakers.
The BassLink 4sc incorporates an Infinity-developed phantom center channel. This allows you to dial in the imaging of your car audio system. A wired control allows you to change the phantom center channel image mode.[/FONT]
Half of my speedo now is in the dark.. Any one knows where to get the replacement bulb or the...
