KVY-534DVD
http://img80.imageshack.us/img80/7243/img0972.jpg
By frankaboo, shot with http://profile.imageshack.us/camerabuy.php?model=Canon+DIGITAL+IXUS+75&make=Canon at 2009-04-02
General Features
• 7.0 inch Wide Colour TFT Active Matrix Display
• Number of Pixel: 336,960 pixels
• Screen Size:W154.1 mm x H87.1 mm
• New Full-automatic "Z-action"Open/Close Mechanism
• Motorized Tilt Angle Adjust (8 steps)
• Motorized Back and Forth Display Position Adjust (4 position)
• Interactive Touch Panel Control with Full Graphic User Interface
• DVD Disc Menu Direct Touch Operation (Highlight Control Mode)
• Monitor Panel Key (Variable) / Head Key (Red/Green)
• TV Ready with Optional TV Tuner Unit (KTC-V300P/N)
• OEM Wired Remote Output
• Background Customize
• Supplied with Remote Control Unit
Audio/Video Features
• Maximum Output Power : 50W x 4 (MOSFET Power IC)
• 2 Preouts with 2V Pre-output Level
• 1 RCA AV Input with Mirror Mode function for Rear View Camera
• 1 RCA AV Output
• Video Input Signal Automatic Detection Mode (Normal/ AUTO)
• System E's+ (Built-in HPF/LPF)
• System Q-Ex
• Dual Zone Source & Volume Control
• Attenuator(-20dB) with Smooth Volume Return
• Installer & Backup Memory (Store & Backup Audio & Video Settings)
Tuner Features
• FM/MW/LW 24 Station Presets (18FM, 6MW & LW)
• RDS with Radio Text
• K3i Clear Reception Tuner Circuit
• AME (Automatic Memory Entry)
• Up/Down Seek Tuning
• Local Seek
• FM Stereo/Mono Selector
DVD/CD Features
• DVD Audio/Video/-VR/±R/RW Playback
• VCD Compatible
• MPEG 1/2 Video File (.mpg) & JPEG File (.jpg) Playback
• 24-Bit D/A Converter
• AAC, WMA, MP3 Files Playback with ID-3 Tag Display
• CD Text Ready
• CD-R/CD-RW Playback
USB Features
• USB Interface x 1
• iPod USB Direct Connection with Optional cable (KCA-iP300V)
• iPod Audio Direct Connection with optional cable (KCA-iP300V)
• Power supply through USB port
• MP3/WMA/AAC Playback
Selling at pm for best price
DDX7034BTCOLOR]
http://img66.imageshack.us/img66/4122/img0969.jpg
General Features
• 6.95 inch Wide Colour TFT Active Matrix Display
• Screen Size:W156.2 mm x H82.4 mm
• Motorized Reverse Tilt & 5 Step Tilt Angle Adjust
• Skin Change (3 type)
• Background Customize (3 presets)
• Key illumination (Blue)
• 3 Gold Preouts with 5V Pre-output Level
• 2 RCA AV Inputs
• 1 RCA AV Output
• 1 RCA Video Input for Rear View Camera
• RGB Input for Navigation System (KNA-G431)
• Dolby Digita Sorround/dts Sorround
• Dolby Pro Logic II (for 2ch Source to 5.1ch surround)
• 13 Band Garaphic EQ/ Digital X'over/Digital Time Alignment
• Sound Management System (Type of Car & Speaker Size for Each Channel Selectable)
Tuner Features
• RDS with Radio Text Plus
• Local Seek
DVD/CD Features
• DVD Audio, Video/-VR/±R/RW Playback
• DivX Playback
• VCD Compatible
• CD Text Ready
USB Features
• USB Interface x 2
• iPod Audio Direct Connection with optional cable (KCA-iP200)
KDV-MP5343U[COLOR]
http://img80.imageshack.us/img80/8214/img0971.jpg
General Features
• Detachable Faceplate
• Full Dot LCD Display
• Rotary Encoder for Easy Operation
• OSD (On Screen Display) Operation
• Key Illumination (Blue)
Audio Features
• Front AV Input
• 3 Preouts with 2.5V Pre-output Level
• 1 RCA Video Output
• Separate Bass/Treble Control & Source Tone Memory
• 7Band Equalizer
• Sub woofer Level & Frequency Control
DVD/CD Features
• DVD Video Playback
• DVD±R/RW Compatible
• VCD Compatible
• WAV, WMA (Windows Media Audio) & MP3 Decoder with ID-3 Tag Display
• MPEG 1/2 Video File (.mpg) & JPEG File (.jpg) & Divx Playback
• CD-R/CD-RW Compatible
• Divx certified
USB Features
• Front USB Interface with slide protection cover
• iPod USB 1 Wire Direct Connection with Optional cable (KCA-iP100)
• iPod USB& Front AV input 2 Wire Direct Connection with Optional cable (KCA-iP240V)
FM/AM Tuner Features
• FM/AM 24 Station Presets (18FM, 6AM)
Product Name Description Release Date File Download File Size {KB)
KDV-MP4343[COLOR]
http://img80.imageshack.us/img80/4935/img0970.jpg
General Features
• TDF(Theft Deterrent Faceplate)
• 14 Segment FL Display (8 Digits, Text scroll)
• Digital Clock (24H)
Audio Features
• Rear/Subwoofer/Av-out Switchable
• Separate Bass/Mid range/Treble Control & Source Tone Memory
• Front Aux Input
• Fader & Loudness Control
DVD/CD Features
• DVD±R/RW Compatible (Video Format Only for Visual Playback)
• VCD Compatible
• WMA (Windows Media Audio) & MP3 Decoder with ID-3 Tag Display
• MPEG 1/2/4 Video File (.mpg) & JPEG File (.jpg) & Divx Playback
• CD Text Ready
• Random/Repeat Play
• Divx certified
KDX-XBT8013U[COLOR]
General Features
• Flip-down Detachable Faceplate & TDF
• 64 Color Full-dot FL Display (High brightness)
• Security Code function & DSI
• Rotary Encoder & Multi Control Wheel for Easy Operation
• Auto Dimmer Function (Display, on/off)
• Display Off mode function
• Supplied with Remote Control Unit (RC-547)
• 2-way Telephone/Navigation Mute
• Manual Dimmer Function (Sub Illumination ,3step)
• Emotional Illumination Effect
Audio Features
• 3 Preouts with 4V Pre-output Level
• AUX Input (Rear)
• Subwoofer Level & Low Pass Filter Adjustable
• Built In Amp Mute Function
• System E's+ (Built-in HPF & LPF)
• System Q-Ex: Preset & Full Manual Sound Control
• AUX Input with Optional Unit (CA-C1AX or KCA-S220A)
• Attenuator (-20dB) with Smooth Volume Return
• Installer Memory/ Backup Memory
Single CD Features
• AAC (Advanced Audio Codec) Files Playback created by ex. Apple iTunesTM for Windows
• WMA (Windows Media Audio) & MP3 Files Playback with ID-3 Tag Display
• Multi-session Disc Playback
• Folder & File Name Manual Search Function without Stopping Audio-play
• 24bit D/A Converter
• 0-bit Mute
• CD Text Ready
• Supreme
• Random/Repeat/Scan Play
USB Features
• USB interface ready (Mass Strage & iPod 1 Wire Direct Control)
• iPod 1 wire Direct Connection with Optional cable
External Media Control Features
• Dual External Media Control Capability (with Optional KCA-S220A)
• DNPS (Disc Name Presets) with Compatible CD Changers
• CD Text Ready with Compatible CD Changers
• Direct Access with Remote
• Random/Repeat/Scan Play (Disc/Track)
• Amp Control System with '04-'05 High-end Amplifiers (Max. 8 Amps Controllable)
• Amp Information Display on Head Unit (Voltage/Current/Temperature/Fan Speed)
• OEM Remote Interface
• TV Control
• Optional Apple iPod Interface Ready (KCA-iP500)
• Bluetooth Hands-Free Profile / Audio Profile with Optional Unit (KCA-BT200)
• SNPS (Station Name Presets)
• Selectable Channel Spacing
built in bluetooth
KDX-X7013U[COLOR]
http://img21.imageshack.us/img21/4227/img0910l.jpg
General Features
• 4 Line Mono Full dot FL Display
Audio Features
• AUX Input (Rear)
Single CD Features
• 0-bit Mute
• CD Text Ready
• Supreme
USB Features
• TV Conrol
http://img516.imageshack.us/img516/7411/img1048.jpg
By frankaboo, shot with http://profile.imageshack.us/camerabuy.php?model=Canon+DIGITAL+IXUS+75&make=Canon at 2009-05-04
one year warranty
all item is not included installation ..
location at puchong (klang valley) /old klang road (klang valley)/ klang/(north) bukit mertajam
plz call/sms/pm K.C.ho or Jazz
for more info..
frankie: refer to mr jazz Jazz: 019-3121416 (Puchong & Klang valley)
mr K.C HO : 019-6689 585(klang)
we also accept :
http://img140.imageshack.us/img140/7840/nbepayphor02.gif
By frankaboo at 2009-03-26
http://img99.imageshack.us/img99/32/mcvsaccpth065gif.gif
we also have a installment plan too :
http://img99.imageshack.us/img99/5607/installment.gif
General Features
• 1 RCA AV Output
• System Q-Ex
Tuner Features
• Local Seek
DVD/CD Features
• VCD Compatible
• CD Text Ready
USB Features
• USB Interface x 1
DDX7034BTCOLOR]
General Features
• 2 RCA AV Inputs
• 1 RCA AV Output
Tuner Features
• Local Seek
DVD/CD Features
• DivX Playback
• VCD Compatible
• CD Text Ready
USB Features
• USB Interface x 2
KDV-MP5343U[COLOR]
General Features
Audio Features
• Front AV Input
• 7Band Equalizer
DVD/CD Features
• VCD Compatible
• Divx certified
USB Features
KDV-MP4343[COLOR]
General Features
Audio Features
• Front Aux Input
DVD/CD Features
• VCD Compatible
• CD Text Ready
• Divx certified
KDX-XBT8013U[COLOR]
General Features
Audio Features
• AUX Input (Rear)
Single CD Features
• 0-bit Mute
• CD Text Ready
• Supreme
USB Features
• TV Control
built in bluetooth
KDX-X7013U[COLOR]
General Features
Audio Features
• AUX Input (Rear)
Single CD Features
• 0-bit Mute
• CD Text Ready
• Supreme
USB Features
• TV Conrol
one year warranty
for more info..
we also accept :
