- Joined
- Aug 9, 2006
- Messages
- 389
- Points
- 1,516
Peerless
from Denmark
(Previously known as Peerless-V line or Vifa)
[FONT="]SDS 6-1/2" Woofer 4 Ohm[/FONT]
The Superior Dynamic Sounds (SDS) Series provides the highest-quality woofers at very reasonable prices.
Applying the best in Danish craftsmanship with very affordable price, these audio transducers are ideal
for use in car audio, small surround sound speakers, compact monitors, and even as the midrange component in 3-way or multi array systems & can also be used in a wide variety of end user products and applications.
[FONT="]Specifications:
*Power handling: 60 watts RMS/110 watts max
*VCdia: 1"
*Le: 1.0 mH
*Impedance: 4 ohms
*Re: 3.7 ohms
*Frequency response: 38-6,000 Hz
*Fs: 36.8 Hz
*SPL: 89.5 dB 1W/1m
*Vas: 1.38 cu. ft.
*Qms: 5.35
*Qes: 0.27
*Qts: 0.26
*Xmax: 3.2 mm
*Dimensions: A: 7.15" (6.45" across flats), B: 5.75", C: 3".[/FONT]
[FONT="]Price: RM 300 per pair [/FONT]
[FONT="](Very Good match with below VIFA XT tweeter)[/FONT]
http://www.zerotohundred.com/newfor...ts-vifa-1-dual-concentric-tweeter-xt25sc.html
XT25 tweeter + SDS 6.5” Mid Bass = RM550
Contact: 012=9142998 (Lim)
from Denmark
Ø Coated paper cone with rubber edge
Ø Smooth, extended response
Ø Premium sculpted stamped steel chassis
*VCdia: 1"
*Le: 1.0 mH
*Impedance: 4 ohms
*Re: 3.7 ohms
*Fs: 36.8 Hz
*SPL: 89.5 dB 1W/1m
*Vas: 1.38 cu. ft.
*Qms: 5.35
*Qes: 0.27
*Qts: 0.26
*Xmax: 3.2 mm
