Need suggestion and experiance comment
AE75
Need suggestion and experiance comment on intake
Recently I need to slight mod my blacktop on intake, and there are a few option for me to do.
1. Trumpet eg:
http://202.76.227.240/images/51/5176665644.jpg
2. ARC magic box eg:
http://202.76.227.240/images/54/5405770626.jpg
3. Tom's Super air intake eg:
http://202.76.227.240/images/60/6043705829.jpg
So which 1 is the best upgrade for street use?
AE75
all 3 items are diffreant function i believe. if no problem with u to get all 3 items..and RM second issue..u can put all together...and ur engine bay look nice..and can say...woooowwwwww when someone open ur bonnet...
AE75
If put only 1 of these, which 1 is the best?
haha...i don think there is a call the best...else other no one will invest dy...just which 1 most suit u...maybe in terms of torque range, top speed???, noise level & etc...just my opinion lor...
go to no.1 + with hks mushroom type air filter
or
why not like this..
I've seen blacktop with the trumpets .. evil :D but very noisy :( The Tom's one looks promising .. and that ARC ones so expensive ..
hi bro AE75... picture no.1 look very familar.. hahaha
Tried no.1 on svt last time.. improve low and mid range of RPM together with no. 2 item..
but shud be no.1 +2 most expensive in investment i guess..engine bay look become impressive.
currently using no.2 with HKS mushroom on BT.. not bad performance but looking wise still no.1 look greats ....
i never try picture no.3.. seldom can get the original from TOMs. so no comment on this.
The no1. is for SVT , if you are using BT then you have to mod quite alot . I used to use No 1 & 2 together last time during SVT and is quite nice. Attached a picture for you.
Now using no 3. If you use no 3, you have to extend your air intake hose and use small size battery. If you are using bigger batt, then wait till your batt "kong" then can cahnge together. Quite troublesome. This is "Chiplak" TOM'S hehe. HKS Mushroom inside. Prevent hot air.... I think..
wah bro danny.. need to use this word meh ? " chiplak"
ur svt setting same as mine last time..hahahhaha
Ya ma. copy 1 ma... buy from JB guy forgot his name...
Ya. I still miss my SVT. Should have just change the wiring to map sensor. KNN after change BT then my mech said SVT wiring can mod to BT without using air mask.....
hahahaha..
agree with u .. i still missed my svt engine sound yer.. look more solid than bt.. hahhaha
or
why not like this..
Direct trumpet I not so like, because it noise and a bit heavy in FC.
Haha... I stolen picture, hope you not mind :P
Thanks for sharing experience. Picture No 3 is TPS shop selling 1 le... not the real 1 also.
Tom's got production for blacktop also right? Because 1 faller said it is from blacktop, but when search online. No saw this information pulak.
About item no 3, hence if we use any aluminum plate to prevent the hot air, and the result also will be same as that?
TOM's only produce (1) for SVT. For BT ppl prefer run on open pod so no selling point for TOM's to make another.
Lari topic abit...anybody knows where to can trumpets that can fit straight into standard SVT airbox?
J
Replies
55
Views
8K
J
