if u go for hondata, u dont need others. hondata controls almost everything, if not everything.. hahaa
ooo k2 tq 4 ur info but this moniter only support few managmnt kn like hondata n other few. luck 2 hondata user hehe .hmm well i wish my exprimnt with the ultimate go well n i gain some experience just like u .since my car is not a daily drive car if thing did't go well im sure going 2 consider hondata o other stndalone managmnt
la eh ,after install hondata then u go for a dyno to tune the cam deg ke ??
i 2 wnt 2 be a new vtec hero hehehehe
give me a chnce 2 feel the true potentioal of my modification heheheh.hmmm n if the injector drivers ECU fry my idle will go crzy kn no mether wht i do to. so tht mean i hve to check on my ecu again la hmm dame always do the same thing so many time so ur saying tht if b20b with hondata = madnessla eh ,after install hondata then u go for a dyno to tune the cam deg ke ??
Actually the sequence is wrong, it's degree in the cams, go dyno, see peak torque at what rpm, not satisfied, adjust cams again, tune again, repeat until can get good power la.
if ur so kind do left me some tips on hondata overlayi 2 wnt 2 be a new vtec hero hehehehe
If you know how to use windows movie maker, you're 70% there already.. If you already know how to use video editing programs, it's 90% there.. lol..
haaaaa ic now i get a proper answer for the injector issue ,ala dont be like tht lagive me a chnce 2 feel the true potentioal of my modification heheheh.hmmm n if the injector drivers ECU fry my idle will go crzy kn no mether wht i do to. so tht mean i hve to check on my ecu again la hmm dame always do the same thing so many time
Actually if the ECU fry due to driving H22A injectors without resistor box, you will be dealing with the ECU repair master E-tech for a while longer.. hahaha
n now i need 2 find resistor box for the H22A injector, hmmm how much will it cost me n how am i going 2 trace it
just wondering,are all d resistor box frm any honda models dat uses them d same?i mean 4 example,a resistor box frm a Prelude & an Accord.r they actually d same?i'm running OBD0 wiring w H22A injectors as well.whn i was still on small V B16A injectors,muh resistor box oredy fried once....changed 2 a unit taken frm a SOHC VTEC F22B.....n recently fried oso...now m using a unit frm a SM4 Accord.seems 2 run pretty well,haven't taken out d plug 2 check tho....
n 4 wiring matters,i rather sum1 do it 4 me ol skool way by twist w hand,tape it PLUS cable tie it...rather thn sum "hero" dat duno how 2 do proper soldering go n try but make a mess in d end...hahahahahaha
and how much will it be roughly :hmmmm:
