Ken Ji's super-smooth 2:26.3 Onboard Lap Video at the 2010 Time To Attack Finale
Tom
TIMETOATTACK
http://www.timetoattack.net/wp-content/uploads/2010/12/5253356365_eae13188f4_z-600x400.jpg
Time To Attack superstar Ken Ji shaves 2 seconds off at the Finale last Sunday with his HKS Time Attack Nissan Silvia S15. Best Lap: 2m 26.3s : After struggling with oversteer at 'ZTH TTAS: The Final Call', some setup changes were made to the car to give the rear end more stability. Unexpectedly, handling was dogged by understeer from turn-in to apex today - cornering speeds at T5-6, T7-8 and T-12 weren't fantastic. But more importantly, the strong understeer (even when trail braking into corners) meant that i either had to back off to let the nose hang on, or open up the throttle and deal with oversteer.
YouTube - HKS Time Attack Silvia @ ZTH Time to Attack Sepang: Finale
The high track temperatures may have contributed to the lack of grip (it was measured at 44 deg C at 5pm!) - tail started skating around under braking in the 2nd session, and i overshot my turn-in points for T1 and T9 pretty bad heheh.
Post-mortem with Denis Lian at day's end suggests that I may have gone the wrong with with damper adjustments... oh well, live and learn ;-)
Still, it was good enough for a new personal best time of 2m 26.3s today. Many thanks to all at Onward Motorsports (OMS) and HKS Garage R for their tireless efforts in getting the Silvia to where it's at. Faster times to come! :)
Super smooth? Doesn't seem like it. Powerfull car though...
He was pushing quite hard and therefore having some oversteer on the edge moments, but that's how it should be if you're pushing to the limit and overall still a pretty much in control lap hence the good lap time. Notice he was pulling almost 1.3-1.5g on some corners.
at the speeds he's going, seem like the G sensor reading is a bit off.. can't trust the g-sensor if the car bodyrolls too much.
his gearchanges werent that smooth too, could use more heeltoe action, plus the turbine lags a bit. just a bit.
true about the lag and heeltoe, then again driving a car with full racing overall in malaysian weather ain't comfy so it's natural to make mistakes but like the driver said, live and learn.
is no g sensor error lah!!! dis one is use gps one not afect when roll!
nice laptime n drifting but no need say car say setting
is your car for quite long alrdy
you drive many lap can feel car feel how its change lap by lap
so you drive that time if miss point tail slid all these is jus driver mistake
dirver mus know the car mus ajus to car
exampel if 3 lap brake not so bite alrdy den driver must ajus braking to earlyer
wow a gps that detects g forces, that a first. Considering gps in malaysia are not even supporting MSAS/WAAS.
G force is measured via accelerometers, and due to their design, they are also affected by gravity and tilt, that's why always got to calibrate when using it the first time.
Personally, i'm using Innovate Motorsports one. The only way I can pull 1g below 100kmh is by using it on a car with excessive body roll. Most of the time, hardly hits 1g. If exceed 1g even the front end traction will be so so already.
Btw, I wonder if you know what kind of g's cars pull on a skidpad. It's really not that high. Even a friends skyline only manages 1.3 before loosing traction. And only at higher speeds.
brudder shrioitenshit you dunno how gps get the speed or gforce?
gps onli see the position
the speed is calculate from position n time
go one more step n calcultae the acceleration aka gforce from the speed and the time
i primaryy skool onli also understand these
dun compare skidpad to track lah
the big turn at the track the steering angle can be small n speed higher so better grips
den oso the track got cambre
plus elevasion change
plus rubber from other car
plus car like dis have the aerodynamic to help
plus car weight low
all combine can make the high g of 1.4
not say is cannot do one
Bro, g force not same with speed la. Gps of course can read speed, like you explained but NOT gforce la. I can confirm motec, haltech, even the nismo r mfd use accelerometers, not to mention many more telemetry systems. There is NO WAY a gps can read gforce, I should know, i'm a GPS user and a contributor to malaysian mapping community. Lol, I think my post on gps still sits in the zth gps forums. Though my datalog on g forces already tenggelam deep into zth forums.
And you're right about the camber on the turns. That's why I said, "can't trust the g sensor when there's bodyroll.". After all, I did say that accelerometers are affected by tilt.. Btw, my driving skills pretty lousy, so since you obviously drive better than me, why never compete against these guys. Eh?
I'm only interested in the technical aspect, and from what I can see, it looks like the car having excessive body roll, so that might be the cause of understeer. But can't trust the g sensor fully either, it's still up to the driver and his crew to interpret the datalogs.
Driver skill can't improve a badly setup car.
Guys don't fight la.. we're here to discuss and not fight over opinions.. accept or correct but don't flame..
Good start for the S15 driver if he's still new, don't have to be that shy on the corners :)
wa... KenJi put up his lap vidoe for us to view.. you fellas start discussing gps, WAAS, G force etc... relax la..
Give credit to KenJi la.
Even though he had the car pretty long, it's been constantly improved since he had it.
And even he admits the car and his driving still far from perfect.
brudder dun so corky act gps expert lah
nowsadays got many these kind system one
from many year ago got alrdy!!
pls read properly and learn!!!
http://www.maxqdata.com/products.htm
http://www.protechdevelopments.com.au/VBOX.html
http://www.md.kth.se/body/edu/mme/4F1530/Problems2005/Honda%20Track%20Data%20For%20Formula%20Student.pdf
http://www.gprdirect.com/pit-equipment/lap-timers-dash-displays/aim-my-tach-gps-data-logging-watch.html
http://www.directracingsupplies.co.nz/acatalog/AIM_-_MYCHRON_4_-_GPS.html
oso the car roll not same as road camber
ok good job to ken ki
sure can go faster
No one's saying that driving is not good but it's not super smooth like the title suggests. Would have clocked a better time if he was super smooth....
sure can go faster
Lol, those GPS systems include accelerometers la... some even use speed vs distance to calculate acceleration g-force, not lateral g forces..
You're the one who should go study what accelerometers are. Don't simply claim people don't have knowledge and is simply is keyboard warrior when you are one.
Who's being cocky lol.
I'm still learning btw, but I don't claim to know everything...heck, right now I'm working on a K-series dash harness.. it's been done to death by the americans, but practical knowledge is where it counts in real life.. check my posts lol.. Simple matter to see who's a keyboard warrior and who's not, isn't it?
After all, I'm not a keyboard warrior like you, I actually have to work on cars than post on zth all day long.. if you bothered to check, I don't post all the time lol. so if I don't answer, it just means I'm busy with work.
Oh, road camber doesn't cause bodyroll at high speeds? which physics world do you come from? I was answering the earlier post where the poster said he was pushing 1.3-1.5g, but in real life, g-forces are affected by other factors, including bodyroll, so it's not a given that high g forces reflect how hard the driver is pushing.
Don't want to argue with you anymore, Theory is good to know, but need practical experience as well. Unless you start sharing what you know, with pictures and videos, I'll regard you as a keyboard warrior who knows theory only.
Afterall, Off topic already, want to discuss GPS, come join the GPS forum.. :P
i never meet before pple like dis dunno so much but tok like so sure one
you see the 5 link i posted
all 5 is oni gps
read all very carefully
no accelerometer at all
i know what is call accelerometer i got use b4 n oso got use gps b4
you dun belive me den ask kengi straight lah
ask garager n axis straight lah
nothing more to talk alredy
i dun care wat harness what gps forum
here is here
your word your word
wrong word is wrong
right is right
you
are
wrong
To be honest, I would really like to know how a GPS system could be used to measure lateral G.
all 5 is oni gps
here is here
your word your word
wrong word is wrong
right is right
you
are
wrong
Up to you lah, win in forum only.. troll.
---------- Post added at 08:07 PM ---------- 6 hour anti-bump limit - Previous post was at 08:06 PM ----------
Ask laptimer la.. he seems to know.. lol.. love to hear his technical explanation on it.. hahaha.
Ground station also don't have in malaysia, and suddenly can estimate
lateral acceleration at sepang track using geolocation data...
From his own article. Seems like he is epic keyboard warrior but never read the articles he quote.
Do remember the word is 'estimated.' not 'measured'
Maximum lateral acceleration is in the order of just under 2g, but this is probably slightly overestimated by the GPS measurements and is not corrected for vehicle roll. There is a similar case for longitudinal accelerations, but even so, the vehicle is still negotiating the course at very high levels of acceleration compared to the average road car (maximum lateral acceleration for a road car is around 0.8g).
From his quoted article.
Waste my time only. I thought can actually measure with some magic GPS function, but in the end, it just uses high frequency tracklogs and estimate. Cannot read / measure g's directly lol.
Theory =/= real life.
LAPTIMER is a [email protected] said...ok guys....
the way he talked i already knew this loser got no car...he is just a ps3 driver"and i dont think this loser got money to buy a ps3....hahhahahaha...maybe try out at sony store"freeloader"...driving sim expert wannabe...kakakakakak
I Vote LAPTIMER AS "ZEROTOHUNDRED Biggest LOSER"No.1":)
