Ask laptimer la.. he seems to know.. lol.. love to hear his technical explanation on it.. hahaha.
Ground station also don't have in malaysia, and suddenly can estimate
lateral acceleration at sepang track using geolocation data...
you so rude shiroetinshit!
hello is measure not estimate
dun anyhow say can
ask you your normal car how the speed is know?
is measure from wheel rpm after knowing circumference and derive
you wan to say your normal car speed is onli estimate ??
you knows how de accelerometer work? is by physical move and voltage or capacitance change
so the gforce is derive from de movement hahhahahahahhahahhahahahahhahahahah
so if you tink normal car speed is only estimate
den accelerometer is oso consider estimate
the true is accelerometer gps and normal speed is all measure one!!
ah seng not supid ok! dun anyhow say ting whack me cos my english not power
my understan is not bad ok
not say very good but enuff to see de rubbish ok!!
n i can see your rubbish!!!
gps is see the car position many time in one second
from change in position over time it calculate speed
you understan derivation or you need ah seng teach you??
go one more step and derivation the speed give you acceleration aka gforce
dis one is for gforce longitude
for gfroce lateral is same
with 3 point know de arc n de distance of arc n oso know de radius
with these calculate the gforce oredy by equation below
acceleration (gforce) = speed^2 / radius
don't say what ground station lah
dat one is for accurate compensate for de gps drift dis i oso know
but to calculate gforce while driving and every few 0.1 or 0.05 secon the gps drift is no factor
the pdf tok abt the gps error is actually wrong
you see gps n accelerometer data on same car
the gps usually filter and the lower the hz the more filtering naturally and always less than accelerometer number
oso de car use in the test can do 1.7 sustain lateral gforce on flat smooth skid pad
so on a circuit sure can spike jus under 2
also if the antena is put away from cg of car the number can spike higher oso
g-g trace include spike writer forget is not say sustain unless many point at there
can see there is not many point there most is concentration ard de 1.5
accelerometer oso need calibrate or got error oso
even temperature mus have de compensation table
you charles brudder is it? you all same no thinking style one!!
LS1 even more rude say the dirty word !! can he be ban for saying such work?
... I'm looking for the standard size filter not the mushroom filter...
