A-Spec Racing
Sub Frame Reinforcement Brace
- Available for Honda Civic EK
- Available for Honda Civic EG
One of the best suspension modifications you can do to improve the way your Civic handles would have to be upgrading or adding a rear sway bar. Unfortunately, the sub frame on Civics tends to rip, or tear out, if you go much bigger than the 13mm bar that comes on the Si model Civic. There are a couple products available that address this issue, and this article is going to focus on installing one such product from A-Spec Racing. ASR has designed a very beefy sub frame brace that prevents the tear out normally associated with using large sway bars. I am going to show you how to install this brace in a 6th gen Civic to support a 22mm sway bar from an Integra Type-R. In this install, I am also adding aftermarket Lower Control Arms...mostly for the ‘bling’ factor, though they are a bit lighter than stock and will replace the worn out bushings in the OE arms.
Price is negotiable
Interested please call or SMS me @ 0122382265
COD location @ Subang USJ Taipan McD
Price is negotiable
asr honda civic & integra rear sub-frame reinforcement brace model 28661 (5).jpg71.4 KB · Views: 165 -
asr honda civic & integra rear sub-frame reinforcement brace model 28661 (7).jpg66.2 KB · Views: 177
