4G15 carb..full tank=below 400km
Your FC seem teruk to me... My Proton Sucka 4g13 full tank RON95&97 can give me 500+km... Maybe your car too old and need some overhauling job? Tires pressure?
maybe too old...i already do top overhaul becos minyak naek atas (early 2008).my tyre presure 30psi(front n rear)im using 195/50/15.i never put ron95 on my engine. usually i use ron97. v-power racing does not improve anything(power or FC) on my car.
any suggestion bro?what do you do on your car?:adore:
my fc kinda suck also, rm75 for 300km . Any solutions? the only mod i have is pz extractor, straight tru mid bullet, and stock exhaust.
Mine is all stock standard just use Eneos Eco Touring 10-40 nia... Your car can have a lot of factors to bad fc so I can't really tell why... Best is to get someone skillful in engine parts. But then, if everything is ok, I suspect your carb. I don't know if radiator or gearbox do cause fc problems also because I once got another carb honda with such problems when they rosak...
What is your previous fc btw?
before changing my clutch, around +/-450km
Salam 1Malaysia...I'm new in automotive arena...(not to new la..). now i drive wira 1.5 carb, i got a prob that is FC prob. full tank can go below 400km. any suggestion from taiko@sifu@master?
mod that i've done:
1. denso iridium ik22
2.4-2-1 exst 1.8 pipe, twin tip rear(like putra)
3.distributor w19(bigger fire ppl said)but feel the same like oem
4.grounding
5.1.6 wira clutch+lighten flywheel
6.service every 5000km with 20-50 oil
hope anyone can help...
convert NGV la sure no fc problem:proud::proud:
---------- Post added at 08:36 PM ---------- 6 hour anti-bump limit - Previous post was at 08:32 PM ----------
can easily find a 1.5 carb at halfcut shop :D
it wont be easy cause taxi drive will be looking for same carb
