worth a try.....
Can't wait to let him do my car's exhaust after CNY.
the bullet comes together with the cat back exhaust system...brand Turbo S...the whole cat-back is stainless steel, including the bullet...i can bare if the sound is only loud, but it is also "pecah" when more than 2.5k rpm...i jus want to make the sound deeper, not annoying...should i change the bullet?? or can a 4-2-1 extractor can solve this sound problem??
i've attached the picture of my catback system below
Just with exhaust modification and fine tuning via piggyback? impressive, do you have the dyno chart?
Sorry to mislead, there are other mods involved as well
- underdrive pulley
- iridium plugs
- proper grounding
- open pod with proper heat shield (improved pick up a bit only)
- repositioning the centre bullet (there is a length formula involved both the bullet and position)
- tightened up the stock fuel regulator to have a higher rate (we o not actually need an AFR because at 3.75-4.2 bar, the stock FR can provide already, there is a trick to this)
- PDT (that also made the idling higher than normal, good for me as having under drivepulley)
- CPS activation at 3.6K rpm instead of 4.4K
- 7.5kg 16in Taiwan rims (ori CPS is 9.8kg!)
- replaced CPS rear spoiler to R3 type (less drag)
- replaced entire CPS bodykit to R3 type (fog lamp holes covered)
- replaced with R3 springs
- removed spare tyre, replaced with slim box sub-woofer
- replaced both front seats with Recaro SR3 and Recaro railings (better lower seating positioning)
- Soundproofed & sound dampened entire car
- proper tuning at DynoJet Puchong with very safe margin
- and of course, a few tricks/tips tuner not allowing for public sharing
- cams pulley (standard)
- cams (standard)
And thought you may want to know
- I am not related or any biz related to tuner
- race/high cams are to be done at later stage, coz it's daily driven and concern about requiring to high rev to move car from standstill as powerband is shifted to higher revs
- Campro is not that lousy after all. As regard to those B16 VTEC having similar capacity, their ultimate official figures is approx 180-210hp with lesser torque to our Campro
- That dyno chart was all done at the same machine, same tuner and same RON95 pumped up at the Shell as I entered to the tuner's place
- not so much on the hp/torque figure, overall is the drivability, eager to launch forward, feel good in acceleration, overtaking and coupled with Neo's handling, you get one value hot hatch at a steal
- handling - the alignment geometry, choice of tyres, and choice of rear ARB to suit your way of tackling corners
Oh yes, to proof my pinch of salt, here are the dyno charts...
To those who know me and this ride, this Neo is still slower than you guys... have seen a few doing 185hp NA
Turbocharged ones are quite similar in hp...but way better in torque. Hence, reaching the Vmax sooner and slightly better top speed.... at the expense of more heat, realibility issues and lost of NA rev free enjoyment.
I know how turbo is addictive as I have a TwinTurbo 6sp Supra so pls do not racun me to turbocharge the Neo! Haha!
I better stick to my original plan then. 4-2-1 it is....... Fuel Consuption is very important. If your car drink petrol, you'll wont enjoy driving anymore. Everytime u hit the gas, pocket 1 hole. Haha~ Thannks for the feedback guys. Feel free to give anymore suggestions.
- passenger - loose her (or him) as the passenger cost at least 10-15hp burnt! ahahhaha
The search of the pocket rocket continues...
after CNY? get it done now so can enjoy the extra torque n hp during the holidays... haha!
cheapest if u go all for cap ayam brand and non s/steel.... of coz u dun mind as those pipes are under the car.... who will see right? Also same as u wear nice nice outside but cheap underwear inside...same concept...heheh....
