Perodua MYVI performance remap chip
DeltaS4
PERODUA MYVI Performance Remap Chip.Upgrade up to 25bhp and 20% torque.no wire cutting.Not void vehicle under warranty.Fast 0-100 time,more fast top speed,more fast over take,more fast throtle response and more sport driving passion.
Below dyno result for 100% stock perodua myvi 1.3.Standard around 85bhp.After install the performance remap chip its increase around 20bhp.Its can increase more if other modification like sport air filter or sport exhaust system install and the performance remap chip will recalibrate to match with the modification.
bro, i dont have service or specialist to remove immobiliser.
---------- Post added at 09:31 PM ---------- 6 hour anti-bump limit - Previous post was at 09:30 PM ----------
Salam..im in shah alam.this my contact no 0196909845 kamy arif.we can make appointment first.Salam.
---------- Post added at 09:33 PM ---------- 6 hour anti-bump limit - Previous post was at 09:31 PM ----------
---------- Post added at 09:35 PM ---------- 6 hour anti-bump limit - Previous post was at 09:33 PM ----------
Salam..100% can if you add sport air filter and sport exhaust system then plus with this remap performance chip resetting and calibrate...according to power to weight ratio no problem for perodua myvi with sport mod plus remap performance chip to smoke the satria neos.The dyno chart only stock perodua myvi.if add sport air filter and sport exhaust system the bhp and the torque increase more.
---------- Post added at 09:37 PM ---------- 6 hour anti-bump limit - Previous post was at 09:35 PM ----------
if got e-manage already..
stil got effect?
Still got effect.Emanage only fool and trick the sensor signal and then send to ecu to reprocess.And its old technology and not so much increase bhp or torque and less in stability because got 3 protocol before the ecu change to little bit performance result.But this remap performance chip is 100% direct command to ecu to reading and process this performance resetting including how much fuel to deliver,ignition timing,air ratio and other variable.And the original factory data still safe and not change.
---------- Post added at 09:38 PM ---------- 6 hour anti-bump limit - Previous post was at 09:37 PM ----------
the dyno chart car..
the myvi is stock or got mods..?
put more detail man..
The dyno chart that Perodua Myvi all standard stocks.Just remap performance setting.
how bad will the fuel consumption be after the mod??
Fuel consumption is normal or not so much different in all driving condition.
---------- Post added at 11:44 AM ---------- 6 hour anti-bump limit - Previous post was at 11:38 AM ----------
Fuel consumption is not so much different with standard mode in all driving condition(normal or sport racing driving style).
---------- Post added at 11:49 AM ---------- 6 hour anti-bump limit - Previous post was at 11:44 AM ----------
bro, kelisa 2nd gen....fujiten ECU
Kelisa obd1 system.Only have piggyback performance chip system.Also increase bhp and torque.
For this price, is there any guarantee on the performance?
100% guarantee.Once install,calibrate and setting,instantly u will feel the power change and increase dramatically.
