Stock clearance sale !!!all must go
dre42
http://img819.imageshack.us/img819/7888/drego.jpg
Drego Imports
STOCK CLEARRANCE !!!
BRAND NEW IN BOX
TD05H -16g ( WATER COOLING )- Mitsubishi EVO ,water cooling , twin fins-16g internal wastegate,
TD05H is twin fins compressor wheel . Flow range is 0.05-0.22 kg/s , work for 50-130kw engine. ( especially for EVO III )
UP TO 350 HORSEPOWER
TURBOCHARGER T3/T4 STAGE III WHEEL BRAND NEW RM1000 NORMAL RETAIL RM1200
http://img262.imageshack.us/img262/2243/t3t4turbocharger.jpg
Uploaded with ImageShack.us
1/8 NPT OIL INLET T3 / T4 FLANGE
FITS T3 AND T3/T4 MANIFOLDS SPECS:
. 50 A/R COMPRESSOR .63 A/R TURBINE.57 TRIM
THIS TURBO CAN EASILY DO 25 psi
Standard T3 Flange,
TURBINE WHEEL:
EXDUCER: 2.48"
MAYOR : 2.89"
COMPRESSOR WHEEL :
EXDUCER: 2.07"
MAYOR : 2.36"
5 BOLT FLANGE SUITS EXTERNAL WASTEGATE
Super T70 turbo RM1400 NORMAL RETAIL RM1600
http://img684.imageshack.us/img684/1696/turbochargert70.jpg
This is a High Quality Turbo, with Big Wheels, Good For 400 to 500 HP Applications, Such as Mustang, Supra, RX7, and other 4-Clyn Engines with high Power Setup. Civic B18, B20, 240SX SR20DET, RB20, RB25, Eclipse 4G63.
PRODUCT
T70 turbo
specs
wet float bearings,
1/8 NPT oil inlet
compressor a/r = 0.70
turbine a/r =0.84
shaft and wheel trim = 58mm
compressor wheel = 56.5mm
diameter inlet 4"
oulet 2.5"
V band rear
oil cooled
T3 flange
rated to 600hp plus,
in stock now ready to ship
TD05H 20G RM1000 NORMAL RETAIL RM1200
http://img638.imageshack.us/img638/9071/tbctd05h20g2.gif
Features:
TD05H TURBO UNIT Utilize external wastegate Made of Quality Cast material Oil cooled & lubricated center section - journal bearing Suggested vehicle with1.6L to 2.5L engine: Up to 300-450bHP 3 Bolt Exhaust flange, 5 bolt downpipe flange All flanges pictured are included as well as internal wastegate
Turbo Specs:
Journal Bearing and oil cooled Inlet: 2 3/8", Outlet 1 5/8" Compressor :60 trim exducer 79.6 inducer 52 0.50 A/R Turbine: 77 trim exducer 49 inducer 50 N/A A/R
T25/T28
RM800 NORMAL RETAIL RM960
http://img804.imageshack.us/img804/2200/t25.jpg
T25 Flange, Dimension: 73 * 40
Oil Cooled, Inlet: M10*1.5, outlet: 2 M8
Max Power: 270hp, spool time at 2500 RPM
Compressor Wheel
0.42 A/R Cold Side
Ind: 37.8 mm
Exd: 59.7 mm
Trim: 40
Turbiner Wheel
5-Bolt Standard
0.86 A/R Hot Side
Ind: 52.9 mm
Exd: 45.47 mm
Trim: 73
25-27 PSI Power Performance Output
Internal wastegate at 8PSI
CNC Machined Flanges
CALL/TXT 0123505832
DREGO IMPORTS
49D JALAN PJS 1/48 PETALING UTAMA 7,PETALING JAYA
Tel: 0377811481
Malaysia ,New Zealand
