The 1 inch is the ID of the master cylinder, not thickness of the servo.. All early Evo is 1 inch, those with brembos comes with 17/16 inch.. As stated its casted with the marking on its side. Pedal travel will be shorter with bigger size master cylinder, but less leverage (more effort need to be applied vs the smaller ID to achieve the same force).how u measured it is 1 inch? u mean the thickness of the servo(black parts) is only 1 inch?? evo's servo are double layer, at least 10 cm thick if i measured the thickness of the black parts.......which is 4 inches ..... for me, no much different.... the 1 inch servo are oem proton or lancer maybe
