rbs are oversquare engines, so it's not about torque hehehehe. Want torque, go for a v8. :p
Guys, not mean to hijack Loki's thread but i have just found that one of my air flow meter's net is broken. I don't know was it broken before i have own the car but the boost stucks at 0.6 bar since then! Is it because of the broken air flow meter or other might cause the problem?
haha thanks pimpin, noticed that the sensor is fine tho the net is broken. In this case i might just drive till its gone for real then get a MAP instead.
i was replacing the A/C compressor in the morning and found that the net is broken and i wonder why :/ but still, 0.6bar for stock? can anyone classify this? I have been search in any forums or google around but still couldnt find one...
Bro kaminari, according to my mechanic, my bnr still using the factory clutch and hasn't been changed yet. Car almost reaching 100k mileage but there's still no sign of slipping or rough shifting.. is 38kg/m torque consider low in rb26? Probably some upgrades will help, coz even the downpipe of my car is stock.. any other suggestions for me? tq all...
I still have my 2 stock afms in my car although i'm not using them since i changed to map. If ur interested, i could sell it to u. Though changing to map is a good idea bro ;)
You using STD ECU bro?Got add-on boost controller?STD boost for skyline is about 350mmHg (0.5bar)
and with minor mod spike to 0.6bar. Boost limit 0.9bar on STD ecu.You will need an add-on boost controller to increase the boost pressure.
His car is far from stock bro..
Ohh then I think 1st step is changing your clutch :), like bro [PIMPIN] said on 100K KM is quite a
wear out clutch if really it`s running on same clutch which ran out from factory. Slipping clutch
make your car lost power and torque in the same time
will definitely replace the clutch next service.. yeah bro pimpin, was lucky to get a very good condition stock bnr34.. looking forward to tt with u guys and learn more from all sifus..![]()
hehe tbanks guys for the info. appreciate that. i guess im gonna keep it stock till the AFM kong then only i will get a rebuilt or something. Another thing is, 2 A/C compressor burn in 2 weeks and couldnt find out why yet!! Could be caused by the heat but the water and oil temp seems ok hmm.. gonna have a good talk with you guys tomorrow morning!
btw, my stock clutch replaced when 130k :dong:
cheers pimpin, i will ask my mechanic to double check again on monday!!
