- Joined
- Dec 12, 2005
- Messages
- 70
- Points
- 1,506
is there any better gearbox than the ageing 4 speeder box in our a33? i notice the latest teana is using cvt gearbox. issit compatible with our car? seriously 3L with 4 speeder is a damn waste!
I don't think there is a better trans for A33/A32 except a manual. CVT is really smooth but cannot handle much power and torque. It will be definitely less reliable than an regular auto especially if you drive the car hard often. Not sure the teana CVT is a belt or torodial system. Need to do some googling. Found it, using JATCO belt. US people saying it last about only 100,000 miles = 160,000km. Which is expected from a CVT. Currently CVT cannot beat a regular auto with clutch and gear in terms or reliability. Mostly due to slippage and heat management.is there any better gearbox than the ageing 4 speeder box in our a33? i notice the latest teana is using cvt gearbox. issit compatible with our car? seriously 3L with 4 speeder is a damn waste!
Totally agreed! In the US , ppl use the Maxima (same model as the cefiro in MY) to compete in 1/4mile races with their manual gearbox! Which means this car can be a luxury vip or a sports saloon! In taiwan you can see lots of broken down cvts which I've seen in a mag. According to the mag, CVT g/box can only last for 100,000 miles or 5years depending on the usage of the car before the belt start to give problems. I think thats why the Scooby gave up their CVT development.I don't think there is a better trans for A33/A32 except a manual. CVT is really smooth but cannot handle much power and torque. It will be definitely less reliable than an regular auto especially if you drive the car hard often. Not sure the teana CVT is a belt or torodial system. Need to do some googling. Found it, using JATCO belt. US people saying it last about only 100,000 miles = 160,000km. Which is expected from a CVT. Currently CVT cannot beat a regular auto with clutch and gear in terms or reliability. Mostly due to slippage and heat management.
Can it be fitted to A32 model?change to manual la~~~
i hav A33 manual complete set
flywheel , bracket , gear level all complete
RM2500
016 623 0313 jun
sb3 said:According to the mag, CVT g/box can only last for 100,000 miles or 5years depending on the usage of the car before the belt start to give problems. I think thats why the Scooby gave up their CVT development.
I should think replacement would cost a bomb coz so kedai potong is the only 'option'.Cannot get the belt replaced?
Cause 1/2 cut is expensive, and you need many things. Not only the G.box and stick. You need a difference engine rear mount, maybe cross member, interior you need the center console, than the clutch pedal, clutch pump, and brake pedal.
You want to use back the auto brake pedal? Press clutch accidental press brake how?
)??? Been interested in this MR2s since I was a kid... hehehe...
