Ts is overwhelmed
Ahemmm... is the engine 4G91 DOHC, he didn't specify also woh... don't play play.
Ts is overwhelmed
he specified already in his first post itself that he wants the transmission and engine to remain as it is and he has no plans of changing it thats why i mentioned above i felt that huge amount of modification might be wasted
but definitely got satisfaction lah knowing got all those stuff under the hood![]()
halo im new here..want some tips from sifu2 in here...how to increase power (PERFORMANCE) for my wira 1.5 fuel injection (A/T)..without changing enjin n manual transmission...my enjin still virgin belum tukar or pasang apa2 lagi..my car feel so berat la...lmbt pick up.i think scooter lagi laju hehe..so plz what can i do wif my car???? plz advice n tips...in malay subtitle kalaw boleh,,,huhuhu...PLEASE DESPRATE da ni....what item i need to buy?![]()
Sorry to spike TS's thread, but I'm using 1.5 A/T as well, 4G15 and planning to opt for 4G93 or 4G93T. How much the cost of it for half cut, roughly ? Will it be a good move for let say, another 5 years of car usage ?
Agreed! I'll try to refrain my self from play play around...
Hmm... If he want to increase performance for properly, better do engine blueprinting as the first step. Then the others can be follow up.
Kalau tak nak tukar enjin dan transmisi, power yang dpt di upgrade tu tak brapa besar sgt la.apa yang boleh buat, slow slow laa ko ubah satu persatu..
Mula2 tukar Air filter, jenis high performance mcm K&N ke, bole jugak tingkatkan power.
Lain2, mcm Exhaust system (terutamanya extractor, bahagian kepala depan tu). tapi aku benci kalau orang tukar ekzos mengaum mcm gila, gerak siput. haha. buat pencemaran bunyi. jadi cari la yg tak bising punya, sbb bazir minyak je.
tentang voltage stabiliser tu mmbantu jugak, tapi tnya la lebih lanjut kat org kedai tu, tntang negatif dan positif effect mnda tu.
Tentang spark plugs tu, tak brapa membantu pun, jd boleh abaikan. tntang penggunaan minyak enjin, guna la semi synthetic kalau boleh, mineral pun ok ja, sbb perkara ni tak rasa sgt pun utk wira.
lagi satu, buangkan laa menda2 yg tak perlu dlm bonet tuu, mcm kotak2 barang2 beg2 berat2 tuu, mnde tu mmg lambatkan pick up jugak. dan ikutlaa jadual service.
tu je la kot mnde basic.
nak lebih, mmg kena upgrade enjin dan gear. sbb wira ada 3 gear je utk Auto.
ok.. what i'm going to write is kinda extreme..
but if u willing to spend some cash.. why not..
the options are :
1. re-bore your engine block & use an oversize piston..
2. Turbocharge it..
3. 4 throttle it..
4. change to a better torque converter (since u don't wanna use manual)..
5. increase gear from 3 gears to 4 or 5 (i've heard of this)..
7. Intake, Header & Exhaust (this is a must)
8. ALL OF THE ABOVE
if use open pod air filter lose power ah for AT? better drop in's?
